power steering in 348 (question) | FerrariChat
Discussion in '348/355' started by lyrm, Nov 29, 2009.
  1. lyrm
    lyrm Karting
    Sep 9, 2008
    176
    spain
    #1 lyrm, Nov 29, 2009
    Hi again.I have a 348 and i hate my hard to move steering... Im thinking to install a 355 f1 power steering rack into my 348, have anyone done this before? is there any "how to" ? im mechanic so i have facilities to install it myself. I need to know if the 355 steering rack will fit the chasis supports of the oe 348 one. thanks in advance
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    It would probably be easier (but still a huge job) to fit the power steering system from a Mondial T onto the 348.
  3. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    very good point
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    {point of comment} On my F355B the steering is very liight, too light to be considered properly weighted. I have considered on this up and comming major to wire-out the PS system and see how it feels unboosted. To do this you couple the PS tubes to each other, and make a similar connection to the rack. This way if you don't like it, you can undo the damage for an hour of labor (or so).
    Also note, the front end alignment has +5 degrees of caster unboosted and +7 degrees of caster boosted. Thus a 4-wheel ride height adjustment and corner weighting is prefered to a simple alignment.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #5 No Doubt, Nov 29, 2009
    My steering is light on my 348. Check your tire pressure and brand of tires and tire condition, first.
    Remove everything from your front trunk, second.
    Change to lightweight rims third (preferably 17" if possible).
    Install Girodisc capped 2 piece rotors in front, fourth. These save over 13 pounds! http://www.ferrarichat.com/forum/showthread.php?t=141825
    You can get lightweight steering without adding a new belt and lots of hydraulic fluid onto your 348 by doing the above, first.
  6. Night life
    Night life F1 Veteran
    7,312
    The city that rhymes with fun in Canada
    Roberto
    Why? this is what makes this car better you actually feel the road, mine is pretty ease to move, No Doubt might be right check your tire pressure etc...
  7. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    Funny you mention that. :):)
    I drove Ferrari512tr's (Paolo's) beautiful 348 Spider a few weeks ago and his steering felt 'lighter' than the steering in my 348. :):)
    My tyre pressures are 32 psi in the front and I think that is good enough. It must come down to alignment, because I SWEAR my car is heavier to steer. :):)
    I remember telling Paolo that his car is easier to drive than mine. :):)
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I've gotten pretty spoiled to running lightweight Pirelli's at 38 psi in front, and heavy capped (retread) Kuhmo's at 36 psi in the rear. Makes a great combination for drifting! I can get traction on demand in the wet by simply not accelerating in turns with those heavy rear tires. It takes serious effort to break them loose, even in the wet, though it does put a smile on my face each time!
  9. ferrari 512 tr
    Nov 16, 2008
    4,180
    Australia
    Paolo
    thanks Pap
    im sure its cause you havent driven yr Immaculate 348 for a while.
