power steering leak | FerrariChat
power steering leak
Discussion in '365 GT4 2+2/400/412' started by bundas, Jan 10, 2015.
  1. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    recommend fixes, please
  2. Ak Jim
    Ak Jim F1 Veteran
    9,627
    North Pole AK
    Please give us some more info or perhaps post a few pictures of the problem area.
  3. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    sure enough the steering pump is leaking. shop down to a slotted nut( 17-18mm). they do not have a tool to remove it.. the water pump is leaking out of the weep hole and front crank seals leaking oil! groan. and remember all this was at NJB. left there with nothing wrong. hard to believe they were so incompetent
  4. GT Jones
    GT Jones Formula Junior
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    I did this a few months ago. after looking all over for a seal kit for the ZF steering box with no luck I went to a local shop - Little Foreign Car Garage in Waltham, MA who fixed it. Ask for Skip. He's an old fashioned mechanic and the ZF box is similar to BMW and Merc boxes. I think our box is only shared with the GTC and an equally obscure Lambo model. He was painfully slow... $35 parts and $250 labor, includes cleaning and nicely painting the box. Fortunately I needed only a little tightening if the gears; everything was in good shape and not worn.
  5. 15765
    15765 Formula Junior
    May 14, 2012
    302
    Las Vegas NV
    Chuck King
    Take 1/2 inch drive socket the outside diameter you need and grind away the excess between the lugs to make it a four lug socket.
    Chuck
  6. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    thanks for the socket tip. saved again by ferrarichat!
