430 - Power steering pump leak question | FerrariChat
430 Power steering pump leak question
Discussion in '360/430' started by FSM348, Dec 1, 2019.
  1. FSM348
    FSM348 Formula Junior
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Does the power steering pump require replacement when only the hose connection is leaking? I've been told the pump needs replaced but it seams like a waste when it's just the crimped clamp section that appears to be at fault. I have a brand new Ferrari PS pump on my shelf but would rather install it when the pump fails, not just because of a small leak
  2. Bill ochrane
    Bill ochrane Karting
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    It all depends on who or whom is telling you to change it.
    I would be at odds to change the pump if it is a dealer.
    If it's your wife telling you to change the pump - Say yes Dear, and change it or you are going to hear about it for the rest of your marriage.
    Window won't go down? You will hear - "I told you to change that pump"!
  3. Rifledriver
    36,769
    I have never replaced one of those pumps. I have replaced many of the hoses under it.
    Red 27 likes this.
  4. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    I appreciate the replies. If the Fiancé had any opinion on the PS pump I would be totally shocked, haha. That being said if there is any inconvenience to be had on a drive with the better half I’m sure it will be my fault regardless if I swap the pump or not. I’ll try to just replace the hose.
    Brian, where do you source the hoses?
    EastMemphis likes this.
  5. Rifledriver
    36,769
    From people who sell Ferrari parts.
    mike32 and JoeTSI like this.
  6. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    After looking up the part #196892 at Ricambi, Algar, AWItalian, All Ferrari Parts Inc and others I could not find a source for the hose. I then asked you if you knew of a source because you stated that you had replaced the hoses on several 430's. I didn't realize I was asking a totally stupid question until you helped me realize my fault. Thanks.
  7. Rifledriver
    36,769
    Be specific if you have a specific question.
    #1 Don't believe web sites.
    #2 Call.
    #3 Get someone qualified to fix your car and they will make it happen. I fabricate a lot of hoses because Ferrari is too cheap to keep stock. I don't just throw up my hands and insult people.
    Ask stupid questions get stupid answers.
    JoeTSI likes this.
  8. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    #1 - Fair enough
    #2 - I did
    #3 - I buy my underwear from K-mart. Qualified enough?
  9. Greg Larson
    Greg Larson Rookie
    Nov 12, 2018
    24
    oregon
    Bob the Builder
    I have an 05 430. My steering hose was leaking at the pump. Tried to tighten the hose clamp but it kept leaking. Bought a new PS hose from Recambi and it fixed it. About $40 bucks. The original hose was hard and brittle compared to the new hose. 15 year rubber tend to dry out. Easy fix. GL
  10. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    I agree, the hose needs replaced. Unfortunately, nobody has one in stock, including Ricambi. I went ahead and fitted another OEM type Otiker clamp to the hose on each side of the original. I expect that should last long enough to source a replacement hose.
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,916
    Isle of man- uk
    Eurospares are showing some used pipes in stock
    Also have a look at Ferrari parts.co.uk
