430 - Power Steering Pump Leaking | FerrariChat
430 Power Steering Pump Leaking
Discussion in '360/430' started by AandSC, Apr 10, 2020.
  1. AandSC
    AandSC Formula Junior
    959
    Jax, FL
    Allen
    Anyone replaced or rebuilt their 430 power steering pump due to it leaking? Mine appears to be leaking from the bottom inboard corner. Seems it should be easy enough to remove the four screws and reseal it.
    The oil on the engine is dry, which is why I’m confident it’s the pump that’s leaking.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    R u sure it is oil and not rubber from a worn aux belt ?
  3. AandSC
    959
    Jax, FL
    Allen
    Mike,
    Definitely a fluid leak. It’s a small leak, but enough that it needs repaired.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Only shows the complete pump on the diagram at about £500, would expect it to have an o ring in a recess but not shown as a spare or a repair kit. Will have a look on workshop manual disc to c how it comes apart
    AandSC likes this.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Just shows how to change the pump, looks like AC compressor needs moving to get access. No exploded diagram.
    AandSC likes this.
  6. AandSC
    959
    Jax, FL
    Allen
    Mike, really appreciate you looking. Upon further research it turned out to be the hose clamp by the pump. There wasn’t any of the normal residue on the hose itself but there was some at the pipe. Cleaned everything up, put a new clamp on and will see if that did it in a few miles when it’s time to do the fluid changes.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    That makes more sense as some of the black looked like it was from the aux belt- r u changing that as not an expensive item. Available from local VW dealer
