360 - Power window issue (360) | FerrariChat
360 Power window issue (360)
Discussion in '360/430' started by RSR993, Jan 28, 2020.
  1. RSR993
    RSR993 Rookie
    Jul 6, 2019
    13
    Jay J
    The power window on my 360 passenger side only goes down but not up. The micro switch will make it dip down but not go up?
    I switched the LH and RH switches. Still the same result.
    By giving the motor manual power it still goes up.
  2. 24000rpm
    24000rpm F1 Rookie
    the ecu probably is the problem. located under the dash, by driver(left)'s left foot.
    EastMemphis likes this.
  3. 24000rpm
    24000rpm F1 Rookie
    Wait, are you saying that only the "pre drop" function isn't doing correct or the whole glass isn't going fully up and down?
    if it is the former, it is adjustment of the switch.
  4. RSR993
    RSR993 Rookie
    Jul 6, 2019
    13
    Jay J
    My window only goes down but not up. I checked the switches they're all good per the multimeter.
    Manually giving the motor power it goes up.
    Ordered a "newer" ECU with 90 day warranty for the windows will report back this weekend.
    Apollo 11 likes this.
  5. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    There's a power connector between the door jamb. Water corrosion is common within the electrical connection pins.
