Power Window Problem on my '76 Euro 308 GTB | FerrariChat
Discussion in '308/328' started by steve meltzer, Nov 1, 2022.
  1. steve meltzer
    steve meltzer Formula 3
    Sep 18, 2004
    1,221
    with Enzo 8995
    My power window on the driver’s side (of course!) of my ’76 308 GTB has this ratcheting sound….sorta like gears not quite meshing, both up and down. The window does move both up and down. I know that to make a precise diagnosis I’ll need to remove the door “card”, but before doing so, I thought I’d seek the experience of the “pros from Dover”. What do i need to be cognizant of? expect to find? thanx steve
  2. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Steve,
    As you know better than most of us, these are Italian cars. What you can expect to find and what you end up finding are usually a universe apart. But since your window is going up and down, and you aren't complaining of it moving at a snail's pace, I would say the issue you are going to find is most likely simple and easily resolved. Good luck!
    Andy
    steve meltzer likes this.
  3. steve meltzer
    Sep 18, 2004
    1,221
    with Enzo 8995
    Andy, Here's what I know about Italian cars....get adult help ASAP. thanx s
  4. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Steve: You can bet it's not going to get better. The window raising and lowering machoism is usually described with some profanity. There are many threads on F-Chat as to how to refurbish them. I just went through the whole process on my passenger window along with adding the extra relays based on Paul's schematic to speed them up. Its not difficult just frustrating. There is a really good Y-Tube video by Franny on this exact subject. Birdman also has an excellent write up on this on his website. Be advised that if you loosen the cable to much it can get real messy if the windings on the spool go wonky.
    Barry
  5. steve meltzer
    Sep 18, 2004
    1,221
    with Enzo 8995
    Barry, thanx again...loved the quip about "The window raising and lowering machoism" (sic).
    I'm pretty certain it's mechanical, not electrical. Same Rube Goldberg in my 330 GTC. s
  6. steve meltzer
    Sep 18, 2004
    1,221
    with Enzo 8995
    Franny's video was excellent. thanx. steve
  7. ClydeM
    ClydeM F1 World Champ
    11,938
    Wayne, NJ
    Clyde E. McMurdy
    I had a similar sound. It was a broken window pulley wheel. The cable was catching on the broken edge making the noise. A trip to home depot and I found a replacement plastic wheel.
    Sergio Tavares likes this.
  8. steve meltzer
    Sep 18, 2004
    1,221
    with Enzo 8995
    thanx Clyde, as soon as i get the card off, we'll find out...suspect something like that. s
  9. mexicruiser
    mexicruiser Karting
    Aug 28, 2012
    241
    Jon
    The ratcheting sound is a “safety feature” built inside the motor pulley mechanism, it is designed to “jump teeth” when overloaded to avoid damage to other parts (car or passenger). If the window “system” (seals, pulleys, cables, etc) is old, dirty, broken or out of adjustment and the electric motor or wiring system still hasn’t lost much power then it can “ratchet” before the window closes, and this requires the very embarrassing “using your hands to push up the window of your italian classic car” technique (best reserved to secluded locations)
    On my car somebody (not me) had canceled out this mechanism by threading a large screw thru both pulley halves, this caused the motor to overload the electrical circuit. After I cleaned and greased the whole system, changed the cables, installed new window guides and fed power thru independent relays connected to the battery, the windows now close reasonably, but my “ratcheting safety system” remains cancelled, it is too damaged from the previous hack job.
  10. steve meltzer
    Sep 18, 2004
    1,221
    with Enzo 8995
    thank you, mexicruiser. hope to get to this next week, and will report in. . steve
  11. steve meltzer
    Sep 18, 2004
    1,221
    with Enzo 8995
    Finally got some adult help and had a look at the PW problem I was having. Of course, we couldn't replicate the weird, ratcheting noise that was driving this exercise. However, with the card and arm rest removed, we could see that some of the electrical connections were corroded, and less than robust.
    I've never used the radio, so how would I have known the wrong sized speaker was torn and shot? With the connections nicely cleaned up (i like "Deoxit") the window is amazing fast and, despite multiple attempts, the noise never recurred. Always better to be lucky and smart. thanx steve
  12. tuttebenne
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    I love happy endings. :)
  13. steve meltzer
    Sep 18, 2004
    1,221
    with Enzo 8995
    @tuttebenne as your sobriquet suggests you should stick with fairy tales. s
  14. BigTex
    79,386
    Houston, Texas
    Bubba
    As you se ine that excellent tutorial, it's probably in your case the worm gear, but once in, you have to sort it all.
    There are also replacement units where you'd have time to fiddle the old ones and still be up and going, show us what you find!!
  15. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    If this is like other autos, perhaps the grease pack at the big gear is old and hardened. Remove motor, remove case and clean old grease replace with new.
    Can be amazing transform
