Powertrain audio from this F355 | FerrariChat
Discussion in '348/355' started by Fredmec00, Apr 13, 2016.
  1. Fredmec00
    Fredmec00 Rookie
    Apr 11, 2016
    29
    Brazil
    Frederico Oliveira
    The slown down and check engine lights in my F355 pop up. Cylinders 5-8.
    The RPM readings on the dash board dropped to 500 rpm and the engine felt like on 4 cylinders. I could still rev the engine up, but the dashboard only showed 500 rpm.
    Question:
    Is the noise recorded in the video below from a F355 2.7 Motronic running on 4 cylinders?
    https://youtu.be/mx2Xbcd28Bc
    Thanks!
    Fred
  2. F355Bob
    F355Bob Formula 3
    Sounds like it. When my 95 would run on 4 cylinders it was always the cat ECU had failed and then the plugs would foul. Removed the ECUs and have never had a problem since. Don't know if this is your problem or not.
