Pozzi Project - '83 Mondial QV | Page 2 | FerrariChat
Discussion in 'Mondial' started by Car_Couture_NL, Nov 9, 2021.
  1. afterburner
    afterburner F1 Rookie
    3,501
    Switzerland
    Urs STEMMLER
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,742
    Argent/Brasil
    Guido
    Apparently you are missing several things on this car. Those were options at Pozzi at the time! :D
  3. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    You can debate if you are missing a tank plate/floor pan, how you want to call it. In NL this was not an option, but I can imagine if this was an option that people think "why pay for it what I cannot see or enjoy" Part# 116565 is the tank plate and I do see the mounts for it on your Mondial :)
    Fuel line may look fairly good, but it can be deceiving. Are the lines soft or hard? The should not be hard. Do you have a record if they have been replaced.
    Center pipes can be deceiving as well. They often start to leak this way and first a new clamp will be put on it, but soon people realize the leaking is there, but less. I replaced them because the end were not good anymore, while the center was still good, but I have seen two cases where the internals of center pipe was totally disintegrating. The symptom of this is that the engine overheats all the time, because particals get into the radiator. (Need to look up the post of @bartzagato)
  4. JLF
    JLF Formula 3
    Sep 8, 2009
    1,709
  5. afterburner
    3,501
    Switzerland
    Urs STEMMLER
    Yes restored from bare metal up, finished with the same underbody coating as the test of the car. That section of the floor pan protects the alloy tanks and the centre section with hoses and gear linkages. Plus aerodynamically extends the flat floor.
    JLF likes this.
  6. enzo360
    enzo360 F1 Veteran
    Aug 1, 2004
    5,441
    Belgium
    Jurgen Durand
    is the glovebox opening? It wasn't when I saw the car.
    Windows were indeed very noisy. And the puddle was under the car as well
    Greets
    Jurgen
  7. Car_Couture_NL
    Mar 8, 2021
    28
    The Netherlands
    Wesley Joosten
    It's opening, just needs a little tap to actually open as the leather is sticking a little. Window is going to be a winter job, and the puddle is most likely a quick fix.
    They did clean the bottom of the car before my inspection as while I had it up in the air everything was bone dry....
    enzo360 likes this.
  8. Car_Couture_NL
    Mar 8, 2021
    28
    The Netherlands
    Wesley Joosten
    WJHMH, of2worlds and MvT like this.
  9. theunissenguido
    Jan 21, 2004
    2,742
    Argent/Brasil
    Guido
    Misschien ook es die porsche wielen proberen ! :D
  10. Car_Couture_NL
    Mar 8, 2021
    28
    The Netherlands
    Wesley Joosten
  11. afterburner
    3,501
    Switzerland
    Urs STEMMLER
    sorry wrong style... c'mon guys! ;)
    of2worlds likes this.
  12. milko1969
    milko1969 Formula 3
    Feb 21, 2012
    1,442
    Breda, Holland
    Milko
    Don’t change the Wheels these originals are the most Beautifull ones and in front and back the same seize.
  13. theunissenguido
    Jan 21, 2004
    2,742
    Argent/Brasil
    Guido
  14. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
