PPI results - thoughts? | FerrariChat
Discussion in '348/355' started by p930, Aug 27, 2014.
  1. p930
    p930 Rookie
    Dec 9, 2009
    27
    Atlanta area
    Sean
    I found a 98 355 spider manual and i got it inspected. Here are the results:
    Compression test:
    195
    195
    195
    200
    195
    195
    195
    180
    Performed a leak down test on the lowest cylinder in compression test. Gauge read approximately 0%.
    Other items to note:
    Small oil leak - possibly oil tank lines. Oil level was low in oil tank
    Engine bay cover on the right side is missing
    Engine cover struts are worn and don't hold engine cover up
    Interior lamp does not work, all other lights function
    Some rock chips front and rear of paint
    Need new tires all around
    Curious to know what people think of the results. I found it odd that one cylinder had a compression reading of 180 but 0 leak down. Is this normal? How much do you think it would cost to get everything on this list fixed?
    By the way, the PPI was done at a independent shop that has some experience with Fcars. The closest dealer was 3+ hours away.
    Thanks for your help!
  2. cuneo
    cuneo Formula 3 Silver Subscribed
    Nov 20, 2006
    2,469
    Seems like a very clean bill of health!
  3. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Something is not right there...
  4. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Since the leak down came out fine......my guess is.......when the comp test was being done it could be that cylinders 1-7 had six rotations for the readings, and maybe he lost count and the last cylinder only got five rotations???? Just a guess. Only real way to know is run the tests again at another shop. This way you have two different comp/leak down tests to look at.
  5. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Ernie, does the 0% leak seem strange? I did not think that was possible - I did not think a valve or rings for that matter can seal that well. I always though they had some (minimal) leak.
  6. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,567
    San Carlos, CA
    Mitchell Le
    I have seen 0% leak down when the moon is just right. It does happen though.
  7. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Looks decent, if she dont smoke on startup after sitting its cool and if you like they way it rides go for it !!
    I only seen zero on a fresh motor on my 5 leakdown testers and that was a Harley Motor
  8. p930
    p930 Rookie
    Dec 9, 2009
    27
    Atlanta area
    Sean
    I spoke to the mechanic and questioned him about the low compression and he said he might not of had a tight seal on the test. He did confirm he did the leak down correctly and got almost 0 leakdown result. What makes me uneasy about this situation is that this is the only shop in town that does work on Fcars and the owner has used them in the past. The shop knows the car. I wanted to have the car inspected by an independent shop but the nearest one is about 3 hours away.
    The cars has about 11k miles and the current owner put in 2k miles in 2 years. Last major done about 2 years ago. Walk away? Proceed to next step?
  9. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    I don't think you should walk but I struggle with the tech not redoing the compression on the one cylinder when it seemed off. It would have taken him 2 minutes to test that cylinder again.
  10. WATSON
    WATSON Two Time F1 World Champ Owner Rossa Subscribed
    Sep 9, 2010
    23,689
    WI
    Will you be using this shop going forward? ...or moving elsewhere?
  11. p930
    p930 Rookie
    Dec 9, 2009
    27
    Atlanta area
    Sean
    I wouldn't be using his shop going forward. The shop is located in Des Moines and I live in Atlanta. Wish i was closer to him, it would of made this process a lot smoother.
  12. plugzit
    plugzit F1 Veteran Silver Subscribed
    Dec 1, 2004
    7,777
    Redondo Beach, CA
    Bruce Bogart
    Buy the car.
  13. Big Lebowski
    Big Lebowski Formula Junior
    Jan 24, 2013
    337
    Peach state
    Brownie
    And if you do buy the car take it to Ron Reineke. Best independent in the Atlanta area.
