PPI | FerrariChat
PPI
Discussion in 'Technical Q&A' started by Spydermak, May 19, 2012.
  1. Spydermak
    Spydermak Rookie
    May 12, 2012
    33
    What kind of inspection does PPI cover? Will PPI inspect for re-paint? Will cover compression test and leakdown test?
  2. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    #2 ttdang123, May 19, 2012
    It varies depending on who is doing it? Attached is a good check list to start from.
    Fill out your profile so someone might be able to recommend a good place to do PPI near you.
    Best of luck
  3. jcurry
    24,153
    In the past
    Jim
    A PPI can be whatever you want it to be, but also dependent on what the current owner may allow. Purchase of a daily driver may entail a PPI completely different than a project car. Who you have perform the inspection will also impact the scope of a PPI. So the answer to your queries is yes or maybe. Physical inspection of the car is just one aspect. A thorough review of records is equally important. Depending on scope of records sometimes much more can be gleaned from what is included as well as what is not.
    Jim
