Prevent rust problems o 308? | FerrariChat
Discussion in '308/328' started by 308 GTB QV, Mar 5, 2010.
  1. 308 GTB QV
    308 GTB QV Karting
    Jan 19, 2010
    209
    I have seen several threads regarding rust problems on 308. It seems to happen on a lot of cars after a while, not so strange since it´a an old car.
    Where will this normally happen? I´ve seen it a lot on lower parts of the doors. Is there anything you can do to prevent this (except for how you store the car)? I read somewhere that due to the way the car is built, water could stay in some tricky places after washing the car for example, causing rust after a while.
  2. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    After a wash, always take your car for a spin; it'll blow the water out of most of the seams.
    Rust usually starts where there is an accumulation of dirt in combination with water. The spot behind the rear wheel-arches, just above the waistline is a good example. It's rather difficult to seal properly without leaving any space for the ingress of water and dirt.
    A second hot-spot are the doors, and this is made worse by the design, or lack thereof, of the rubber that seals against the glass. At the rear-post of the small glass, no allowance is made to let that post pass into the door, leaving some rather wide gaps between the post and the rubber, where water gushes in when you wash the car. The problem is compounded by always present dirt in the bottom of the doors, it stays wet and the buubbles cannot be avoided. I have cut the rubber on my car in order to attempt to obtain a better seal.
    Of course you need to make sure that all your drain-holes are clean and open.
    Ferrari only got reasonably serious about rust-protection in 1984 (I think), but there is some evidence of them doing some work in that direction on my '82 as well. A proper waxoil, Dinitro or Tectyl treatment would go a long way.l
  3. 308 GTB QV
    308 GTB QV Karting
    Jan 19, 2010
    209
    Thanks for good advice! I have the -85 model which should have better rust protection, but I´ve seen pictures on QVs aswell with rust problems, so I will do what I can to keep it away. Regarding washing, I use these high pressure things, but maybe that´s not a good idea then, if the water might pass the seal due to the pressure?
  4. twright
    twright Karting
    May 15, 2005
    225
    Indianapolis USA
    On my 308 GTBi, I found that the coating on the bottom of the inside of the doors was no longer doing anything useful. I cleaned it all out and covered it with POR-15. That should help with any rust conditions on the doors.
  5. JV's89
    JV's89 F1 Veteran
    7,299
    Pittsburgh, PA
    I use compressed air to to get the water out of the cracks and crevasses on my car. I'm on my third ( I'm keeping this one) 3x8 and they all had rust at what I think is refered to as the C pillar where the buttress meets the rear quater panel.
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    Dehumidifier in the garage helps a lot too (unless you live in Arizona!)
  7. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Yes, often due to sloppy workmanship after re-sprays: there is supposed to be a thin line of sealer where the fender meets the C-pillar, which is often forgotten.
    Also have a look at the horizontal part of the fender (hidden by the decklid when closed) where it meets the C-pillar. Water accumulates there at the joint, and it has nowhere to go to.
  8. JV's89
    JV's89 F1 Veteran
    7,299
    Pittsburgh, PA
    Mine has the sealer at the seam between the two panels. The problem area is actually about 2" above the seam on both sides of the car. IIRC my last 328 had the same problem in exactly the same place. As for the area under the deck lid, I know what you mean. Thats another area I get with the air compressor. There are so many areas on these cars where water hides from the chamois cloth. Before I started using the air compressor, I would wash the car, dry it off and then the next time I drove it, trapped water would leave spots all over the car. Water loves to hide around the door handles, mirrors and louvers.
  9. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I have had the early car lower door rust issues and had it repaired. My rust prevention actions are pretty basic. I have not washed my car since somewhere back in 2003. It has only seen rain twice since I have owned it. I just dust it down and use detailer spray. I'll strip and re-wax once a year. I keep it inside and periodicly will take the air gun and blow under the car. So far , so good.
  10. BigTex
    79,380
    Houston, Texas
    Bubba
    VERY bad idea........I use very little water at all and ALWAYS at low pressure.
    The trouble spots in the doors are from poor drain hole location, drilling better ones would help if the cars sees rain....
    The other trouble spots are behind the front wheels and sometimes above the reveal lines at the rear corners.
    Keep your trunk dry.
  11. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Is anyone using one of the electronic anti-rust systems on their 308. Something like CounterAct: http://www.counteractrust.com/counteract.htm
    I have some friends running them on hot rods, but they are pretty rust proof and babied as it its so I'm not sure thats a good test. Just wondering if anyone is using it on a car known for rust... I've fixed my fair share on my car and might consider putting a system on the Ferrari if there is merit.
    Rick
  12. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    I thought in your state that was "Keep your powder dry"?
  13. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    +1
    I've just refurbished the doors on my car - the seam where the door skin joins the bottom of the door is a perfect trap for water. I topped up the existing rust proofing with waxoyl. Provided the drain holes are kept clear it can't do any harm.
  14. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    These 308s were designed in sunny Italy, so, weather protection and rust protection was initially somewhat of an afterthought. Thankfully, these are tube frame cars....much like a kit car....so, when those rockers rust out or the pillars rust out there's not a significant structural risk as is the case in a monocoque car of the same vintage. That's the good news. Bad news is that they like to rust, especially the pre-galvanized ones. Clean out the door bottoms/wheel arches/trunks and keep 'em dry and in the garage is the best advice.
