Pro Street Lighting 328 Replacement Headlights | FerrariChat
Discussion in '308/328' started by TM328, Apr 18, 2009.
  1. TM328
    TM328 Karting
    Jul 26, 2004
    146
    New England
    Does anyone not affiliated with this company have a review of these headlights.
    They make the followong claims.
    This kit features:
    2 7"Round Diamond cut sealed beam conversion housings
    2 H4 Xenon HID bulbs rated at 65/55 Watts, with an output of 90/100 Watts
    2 rubber covers (to keep the housings dry)
    Plug and play no rewiring is necessary
    What is the downside if any?
  2. Freerange
    Freerange Rookie
    Feb 8, 2020
    9
    Knoxville, TN
    Gregory Weate
    Do you have a link to the product? I was just looking at upgrading my lights..
  3. Rifledriver
    37,099
    Its a 14 year old post.
    Dont bother with those. Get Truck Lites 7 inch LED lights.
    JCR likes this.
  4. Freerange
    Freerange Rookie
    Feb 8, 2020
    9
    Knoxville, TN
    Gregory Weate
    Haha, thankyou
  5. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    159
  6. redline76
    redline76 Formula Junior
    Feb 26, 2008
    355
    Venice, CA
    Warren V
  7. Rifledriver
    37,099
    MFlanagan likes this.
  8. Sigmacars
    Sigmacars Formula 3
    1,218
    Just watch out for the wattage the system can only handle so much,I changed mine to LEDs and I had a drop of amps from 5.4 (original) to 2.3 amp per side and was using the original lenses, it was a plug and play 10 min job.
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    FWIW, the Trucklite looks really good but at nearly 4oo bucks each :eek: they are a bit beyond my "acceptable price range," for a pair of headlights even by Ferrari standards! :rolleyes:
    TBF, I will admit that if I did a good bit of night driving on B roads, I might have a different view but I don't do that...
  10. Rifledriver
    37,099
    Less than half that on Amazon. If they are that cheap on Amazon someone else is cheaper.
  11. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    215
    Boerne, TX
    Rodney Bolt
    The drop in current draw makes sense with LEDs as they require a lot less power for equal or even more light. And that's a good thing: less stress on the wiring. Incandescents waste a ton of power in the form of heat in the bulb filament and through the wiring itself.
    My concern with LEDs is the annoying flickering which some produce, most typically with low-budget lights, caused from low-frequency power supply cycling. For their price, I would hope Truck Lite and Morimoto Holley Retrobright headlight cycling is too fast to be perceived.
  12. redline76
    Feb 26, 2008
    355
    Venice, CA
    Warren V
    Well, it was just one of the benefits :p
