Problem 2. Light on suspension | FerrariChat
Discussion in '348/355' started by Serch, May 20, 2015.
  1. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    #1 Serch, May 20, 2015
    Well.
    In the probem 1 I repaired the Lights lifting device. Wow!!!
    Now, another. The Light of suspensión is ON.
    Well.
    I check the two actuator on the rear wheels and the actuators do nothing (neither turn neither make any noise). They are physically well, I dont make pictures of them but I can tell that nothing is broken in these two actuators.
    I dont belive that I can have the two actuators broken...
    Any idea to check in the car??
    Thx, Sergio
  2. Qavion
    Qavion F1 World Champ
    14,304
    Ian Riddell
    What car and model type do you have, Sergio? F348? F355? 5.2?
  3. jochem00
    jochem00 Formula Junior
    Jun 19, 2014
    344
    Netherlands
    well an easy one you probably already check yourself is to see if you get any electrical power at the plugs of the actuators. only for a short period when you turn the ignition keys.
    as the suspension light is on, the suspension computer has not been disconnected.
    do continuity checks on the cables.
  4. WATSON
    23,689
    WI
    Remember, if you start the car three (or more) consecutive times without moving the car, the shock ECU light comes on.
    Start the car and drive it 50 feet (forward or reverse) and the light will go out.
    May, or may not, be your problem.
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ... good info ...... to the OP ... yes, more than one actuator could be having problems, the plastic gears in them are known to fail, as well as the little gear on top of the shock itself.
  6. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    I've driven over those 50 feet but the light is still on, not off.
    I don't believe that I have the two rear actuator broken.... I have to see the front actuators...
    I think that my problema is in the control unit suspension...It is an intuition
    If I check the front actuators and these any work... I can not have the 4 actuatos broken!!
  7. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    Ah.
    My car, F355 berlinetta F1, 3.5
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Just to make sure ..... the light you have on ... is the one with the little arrows pointing to the tires right? or is it the picture of the shock?
  9. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
  10. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    Thank you ferraridriver. A post excellent.
    I can check my motor (out of the car) and them cam move). I think that I have a problema with the switchboard.
    Can be repair this unit ?? or I have to buy one??
  11. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    I have sent you a PM(Private Message)
  12. jochem00
    Jun 19, 2014
    344
    Netherlands
    if you flip the suspension switch to confort, is the light going out and the soft suspension light on the left of the dash going on?
  13. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    #13 Serch, Jun 4, 2015
    Hello jochem.
    Excuse me the delay.
    I add two photos, with the engine running.
    In position confort (the first) and another in position sport (the second photo).
    And you can see, the right lights do not go out.
    And I repeat the test of the actuators. If I apply 12V DC the motor turns
    Do you think that my failure is the ECU??
    Thx, Sergio
  14. jochem00
    Jun 19, 2014
    344
    Netherlands
    Is the suspension trouble light flashing at startup or stays on straight away?
    If it stays on then and you are sure the actuators and shock gears are ok, then it has been too long like that and an error has been stored in the ECU.
    Trip to ferrari dealer to get it reset
  15. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    Hello jochem.
    The light is always ON, not flashing.
