Problem 3. Light ON AirBag | FerrariChat
Discussion in '348/355' started by Serch, Jun 10, 2015.
  1. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    Hello.
    Another problem of my car is that the light of Air Bag is ON always.
    That things can I check?
    Thx, Sergio
  2. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Sergio,
    YOu need someone with a SD system to clear the airbag code.
  3. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    Ops.
    I'll have to bring to official workshop ...
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    You need dealer...
  5. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    In your WSM it states that . The faults can be cancelled {apart from fault #no 9} by short circuiting the pin #no 1 of the diagnosis socket connector towards earth for a time between 5 and 10 seconds.If the fault #no 2 ECU inner failure disappears the sensor resets.
    Whatever this means...lol
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I think they are trying to describe a procedure for resetting the light using the SD plug and shorting one of the terminals to ground to do it. I tried what I think that says when my light was on and I couldn't get it to work. I had read on here of someone else who also couldn't make it happen.
    I've been to the dealer twice on this.
  7. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    I think that this procedure is only for '94-96, not for '99. Could be??
  8. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Make friends with a dealer. I wasn't charged to reset it either time I went.
  9. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Bob
    If you look at the photo in the WSM they only use a jumper wire to the Sd plug and ground.not the scanner.
  10. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Interesting. I will have to read that and give it a try. My light is on. 96 my. It would be great if it works.
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Yes Mike, that is what I tried and I couldn't get it to clear. The yellow cable is the sd plug if you want to try it Ernest.
  12. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Where is 5he yellow cable located? Heck, worth a try. With my luck the airbag ecu is dead. That's the most expensive part, right?
  13. Rifledriver
    37,252
    That procedure does not apply to US models to comply with US law.
  14. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Thanks Brian. That answers that.
    Ernest the cable in question is in the fuse box behind the passenger footwell. But make friends with a tech with a SD and maybe he will clear it for you.
  15. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    thanks.would that mean the same for Canadian models?
