problem at the bridge in Valencia. | FerrariChat
Discussion in 'Other Racing' started by YellowbirdRS, Aug 21, 2008.
  1. YellowbirdRS
    YellowbirdRS Formula 3
    Nov 9, 2005
    1,765
    DFW/RGV/MX
    Xavier
    Problem at the bridge. The bridge is mobile since it opens to let boats in, so there is a gap between the track and the bridge. The gap is of about 3 cm wide, and a few millimeters high. At high speed the gap could move and cause extra vibrations to the bridge.
  2. YellowbirdRS
    Nov 9, 2005
    1,765
    DFW/RGV/MX
    Xavier
    #2 YellowbirdRS, Aug 21, 2008
    up date
    FIA asked to examine Valencia bridge
    By Jonathan Noble Thursday, August 21st 2008, 18:12 GMT
    Formula One tyre supplier Bridgestone has asked the FIA to examine the bridge section of the new Valencia F1 track amid fears that its current configuration could lead to a spate of punctures this weekend, autosport.com has learned.
    The new track around the Valencia port runs over a swing bridge - with a small gap in the asphalt where there is a metal expansion joint to prevent any damage from varying temperatures.
    Although the gap itself should cause no problem for the F1 cars this weekend, there is some concern, however, with the fact that the two sections of asphalt are at varying levels.
    The section on the bridge is higher than the part of the track before it - and the resultant bump, believed to be as high as 15 millimetres in parts - has led Bridgestone to ask the FIA to look into the situation.
    Bridgestone is worried that the bump is big enough, especially with the potentially more susceptible super-soft tyre in use this weekend, to risk causing punctures.
    Hirohide Hamashima, Bridgestone's director of motorsport tyre development, wrote an email to FIA race director Charlie Whiting on Thursday asking him to look into the matter – and enquire if there was any way of ensuring the two parts of the track are made more level.
    "I've written to Charlie to ask him to look into it," Hamashima told autosport.com. "The track is slightly raised (on the bridge), and if a tyre hits it (the lip), it could cause a puncture.
    "It is not so bad, but if they can adjust it then we will be happy. Having the track level will be better."
    The bridge section of the track appears to be the only part of the circuit that has caused some concern – with the rest of the layout leaving almost all the field excited about this weekend's inaugural event.
    World champion Kimi Raikkonen said about the bridge section: "There are a few bumps because I guess they need to turn the bridge sometimes. That is the only place where I found any bumps on the circuit, and one of them is in the middle of the corner. So, that might affect things a bit.
    "But apart from that it looks very smooth and very well done the circuit. We will see tomorrow how good it is in the end, but I expect to have quite good fun."
  3. Senna1994
    Senna1994 F1 World Champ
    Nov 11, 2003
    13,192
    Orange County
    Anthony T
    Wow, how will the effect the race?
  4. 1_can_dream
    1_can_dream F1 Veteran
    Jan 7, 2006
    8,051
    Colorado
    Kyle
    If they're that worried about a puncture couldn't they just switch to the harder compounds? Either way this is getting exciting and I can't wait for this race!!
  5. theq
    theq Karting
    May 7, 2008
    207
    continuim
    Joel
    +1
  6. bigodino
    bigodino F1 World Champ
    13,127
    The Netherlands
    Peter den Biggelaar
    This should be solved and I don't think this will make for an exciting race at all, more likely a lottery.
  7. Gilles27
    Gilles27 F1 World Champ
    Mar 16, 2002
    13,337
    Ex-Urbia
    Jack
    15 millimeters?! Did they just now realize this? F1 is so meticulous, I don't get how this could have been overlooked until the last minute, especially since they've already held other races there.
  8. jk0001
    jk0001 F1 Veteran
    Oct 18, 2005
    6,706
    Sun Coast
    Jim
    It just adds a little more suspense to the race.
