problem carnauba wax went on glass that covers engine | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by ferrari 360 spider f1, May 21, 2007.
  1. ferrari 360 spider f1
    ferrari 360 spider f1 Formula Junior
    Jan 9, 2007
    438
    bern switzerland
    steven
    i know it will sound stupid but
    the other day i aplied meguiars quik carnauba wax and some drops of that white carnauba fold on the glass that covers the engine in the 360 spider
    so i tried to take it away first with a dry pad it resisted affter with water it get worst.
    what can i do to remove that carnauba marks it,s dificult to se the nice engine under that glass im sad.
    next time i will cover all non metalic areas.
  2. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    i would try warm soapy water.
  3. SonomaRik
    SonomaRik F1 Veteran
    this may not be good help but here goes:
    to remove wax, with a sure fire way of always working even on deep pile carpet [hold on, wait for the shoe to drop]
    1. use BROWN paper bags ONLY: no other type paper seems to work, just cheap brown grocery bags.
    2. split it open to expose as much surface as possible: you will use a lot, be surprised how much wax is there.
    3. put iron on high, NO STEAM.
    4. put paper over wax spot, and iron onto the paper
    5. as soon as the wax melts and the paper soaks it up, you'll see the wet spot, move the paper to get a 'fresh spot' and repeat #4-5 until satisfied.
    Now for the shoe:
    Reason I mention this is the glass-temper can problaby handle the iron especially if the glass is pre-heated in the Sun for awhile.
    I know others will have a different approach, like scrubbing, or don't like the head idea, but this method I mention has been used on all sorts of surfaces [wax on wall/paint from overspilled candles] to leather....of course the method needs to be a bit fast on the leather.
    FWIW
  4. 350HPMondial
    350HPMondial F1 Veteran
    5,334
    Edwardo
    (Rik, read his post, this is glass/plexi not carpet,, but, I should have you travel to Colorado to remove a nice wax stain left on the carpet,, in one of my rental homes.) ;)
    Pardon my ignorance, is the 360 Engine cover glass or plastic?
    FWIW,,,, Meguiars makes a plastic polish for plexiglass..
  5. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    360 engine compartment = glass.
  6. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    Don't understand why wax will not wipe right off of glass---Are you sure ift was just wax dripped on there??
  7. Patentman
    Patentman Formula Junior
    Jan 11, 2004
    521
    Boston/Delray Beach
    Barry W. Chapin
    I'd be careful with the iron since the side vents with the hexagon shaped holes around the glass are plastic and melting these with an accidental touch of a hot metal iron would cost you big time.
    Did you try goof off a small area? Be careful with this too as It might mar the finish on surrounding areas?
  8. carwasher
    carwasher Rookie
    Nov 30, 2006
    17
    Central PA
    Jon Rose
    A general rule of thumb at my detail shop is to remove something like this with whatever caused it. Get some more of the same product and wipe it on the affected area
    If it is real glass, not plexi or plastic, the you can use steel wool. Steel wool has various grades. get some "00" or "000". Put a little polish or wax to add as a lubricant and it will clean anything off of any glass
  9. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Fine steel wool on glass. I use it to clean bugs off the windshield.
    It will ruin plastic. Test a spot out of the way first.
    Let us know what the result is.
  10. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    How about a wax remover for paint. The Griot's paint prep or maybe Acryli-clean from PPG as was suggested on another thread. I can't imagine they could harm glass or plexiglass. I can't see how getting wax of glass would be hard but maybe this will help? Good luck
    Jeff
  11. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    Just use warm water and dish sopa it will cut the wax, follow up with glass cleaner, it shouldn't be a problem.
  12. f355spider
    f355spider F1 World Champ
    18,053
    For stubborn stuff, I find that Griot's claybar with a little Speed Shine, works great at removing stuff off glass.
  13. SonomaRik
    I know, thus the comment of 'wait for the shoe to drop' which is to mean, I believe the glass can withstand the temp of an Iron...we are not talking a large amount of heat here, just enough to get the wax melted which is VERY fast and soaked up....if the glass is warmed in the sun the chance of dis-jointed heating is minimal ... but I also believe the glass is meant to be tempered to enjoy high engine temps....I believe this should work and I would try it, BUT, like I said, this solution most likely won't be tried by anyone here for numerous reasons....just my 2cents....
    PS: Do I get to stay in the rental...sounds like a delightful road trip :\
  14. RonnieF430Spider
    RonnieF430Spider Formula Junior
    Jan 25, 2006
    995
    Westlake Village, CA
    Ronnie C
    This is true, especially if you use Dawn. It will cut right through the wax.
  15. 350HPMondial
    5,334
    Edwardo
    Three bedroom, , with one old RN lady in it. She won't mind, as long as you get the wax out of my (her) carpet. LOL
  16. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    What about those scrapers you use for cleaning glass-ceramic hotplates? They are designed for scraping away everything off glass materials while not damaging them.
