Problem gearbox 360 modena | FerrariChat
Discussion in '360/430' started by miguel10teixeira, Feb 28, 2024.
  1. miguel10teixeira
    Feb 28, 2024
    8
    Miguel Teixeira
    Help needed please
    Problem with gear box of my 360 2001 spider
    Was driving fine and suddenly stoped with gear box light on and turns no N position. I Start the car again and drive for 1km more and again happen. After that I can’t never shift any speed. Every time I turn on the key 3 beeps sound and the light of gear box on. Take the car home with the truck and notice the oil of f1 was very low. I put it on level and try the car but no luck. Any ideas???
    Check fuse and relay and looks fine. F1 pump works fine like always, no diferente sound our timer… everything perfect. Only the 3 beeps and light on and I can’t put no shifts on in anyway…
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    Not.much to go on ..
    Any fluid anywhere ?
    Need to read codes
    If you say pump cycles and runs correctly then I would say one of the sensors (potentiometer or position sensor ) or even a clutch solenoid
    Reading the codes stored and do some.timings of pump cycle will.narrow down issue
  3. miguel10teixeira
    Feb 28, 2024
    8
    Miguel Teixeira
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    Has he got a slug of air i system due to his very low oil level, does the 360 have the same air bleed on the valve block like the 430 ? Might be worth giving it an air bleed using it
  5. miguel10teixeira
    Feb 28, 2024
    8
    Miguel Teixeira
    maybe, but to bleed it I need to go inside the gear box system with machine and I can’t go throw don’t know why ‍♂️
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    If it’s like the 430, there is a bleed valve on the valve block under the wing by the f1 pump
    miguel10teixeira likes this.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    By using this bleed you return fluid to the f1 tank with the air, then switch pump on again to get full pressure and repeat bleeding. Just keep eye on tank level as will g down as air released, also another air release on side of gearbx
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    If air got in there , since he drove , it went into the clutch and / or the actuator
    I am thinking he may not have measured correctly
    This sounds like sensor issue to me
  9. miguel10teixeira
    Feb 28, 2024
    8
    Miguel Teixeira
    witch sensor are you reffering to?
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    He needs his TCU upgraded to talk to the Launch machine. Then he can attempt to work on the F1.
    cavlino and flash32 like this.
  11. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    Gear position sensors. Two of them.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    The launch and and most of all the other inexpensive diag tools are unable to connect to the TCU of early model cars
    They keep trying to fix it with software updates but I haven't seen it work yet
    The way to get codes is to have someone with a Leonardo or a Ferrari SD tool check it ..
    If you wrench on you car and want to maintenance, you maybe better off upgrading your TCU to a CS version or a later 360 so that you can communicate with it and do the work
    If everyone who has a launch and a 360 uses the feedback menu item after a failed connection session with the TCU launch will definitely pay more attention and maybe fix it once and for all
    If you want to talk on the phone just drop me a PM and I will send my number
    cavlino and miguel10teixeira like this.
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    I am thinking its good first move as he had a very low tank level, he cannot connect to the codes anyway. Better than changing sensors and then find air in system. Looking at diagram the 360/430 valve block and pump look similar ?
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    Mitch
    If he cannot get into any gear - it may be the clutch position sensor since the potentiometers allow a shift to 2 nd - all a guess here without codes and some timings
  15. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    Yes they both have the valve
  16. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    and that's why we need a working OBD2 port for the gearbox.
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    The port is fine .. it is the software/dongle/ firmware issue - we need to keep sending feedback using the "feedback" button / menu on launch until they get it right
  18. MountuneMr375
    MountuneMr375 Rookie
    Sep 25, 2023
    42
    Wiltshire, United kingdom
    Ashley ward
    I was driving my 360 spider f1 and had a very similar thing happened when I came off the motorway and at the roundabout hit a bump and the gearbox dropped into neutral and couldn't select any gears!! Pulled in switched off and restarted and all seemed ok.
    As I was on the way taking car to garage for the service I mentioned this to the technician and he said straightway it will be the engine cover switch at the back needs adjusting.
    They did this and I have never had the problem since and that was 6 months ago.
    May not be your fault but worth checking.
  19. BillyD
    BillyD Formula 3
    1,829
    Pacific Northwest
    Bill
    So what year cars can the Launch not read? Adding to my list for car shopping.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    #20 flash32, Mar 2, 2024
    Late 2003 and 2004 with TCU numbers 197533 and 211023
    Launch continues to make fixes supposedly to read older TCUs but I haven't seen any improvements yet ..granted limited testing
    All that being said .. if you find a perfect car don't let the TCU version steer you away ..it can be reflashed by @eric355
  21. miguel10teixeira
    Feb 28, 2024
    8
    Miguel Teixeira
    Witch engine cover switch are you referring to?
  22. Qavion
    Qavion F1 World Champ
    14,374
    Ian Riddell
    #22 Qavion, Mar 2, 2024
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    He is probably talking about the latch on the engine bonnet
  24. miguel10teixeira
    Feb 28, 2024
    8
    Miguel Teixeira
    I think it will not be my problem but I will check it anyway… I’m waiting for a friend who has Autel machine to see if I can go throw the system and read fault codes ‍♂️
  25. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,962
    Central NJ
    Dominick
    Unfortunately I don't think the Autel will be any better than the launch ..sorry
    Where are you located ?
