Problem with door handle (outside) on a 246GTS | FerrariChat
Discussion in '206/246' started by Yves Delhaye, Oct 19, 2010.
  1. Yves Delhaye
    Yves Delhaye Rookie
    Apr 3, 2008
    25
    France
    #1 Yves Delhaye, Oct 19, 2010
    Maybe someone here can help me.
    During a couple of days, I noticed that one of the door handles was not coming back to its normal place (parallel to the glass) when using it. I had to manualy put it back.
    See picture enclosed.
    Then, sundently, it stopped working. It is turning loose. The door can still be opened from inside, but not from outside.
    So my question : Is it a broken part in the opening sub-assembly (then which one could it be), or just an unscrewed component (then what do I have to do to fix it myself) ?
    Thanks in advance for your suggestions.
    Yves
    France
  2. UroTrash
    UroTrash Three Time F1 World Champ
    Jan 20, 2004
    38,979
    Purgatory
    Clifford Gunboat
    I fixed one of those last week. Took about 45 minutes.
    (A lady came over, tried to open the locked door, nearly twisted it off.)
    1. Take your lower inner door panel off. this requires about 6 peripheral screws as well as 2 screws in the door pocket. Also two small screws in the chrome cover of the inside door release.
    2. Look inside, maybe with a flash light, and you will see a cable (like a bicycle brake cable)
    coming down from the door handle clipped to a rod that has a interference nut.
    3. using 2 wrenches (13mm IIRC) loosen the nut.
    4. using needle nose pliers, pull the cable through a bit, maybe, 5mm and re-tighten the nut. At the same time use your other hand to push the outside handle to the position you desire.
    5. try closing the door. If it will not close, loosen up the cable just a bit.
    6. If it closes correctly, tighten up the interference nut fully.
    7. While you are there, lube all your pulleys for the window mechanism.
  3. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    IIRC when this occurred on my car the cable had broken.
    I replaced it with a length of bike brake cable I had lying around after removing the door panel as described above.
  4. dm_n_stuff
    #4 dm_n_stuff, Oct 19, 2010
    and while you're there spray some rost-off on the entire shaft.
    As I recall, It can get frozen in place by rust, too.
    Uro, I had to do the same fix three or four times, including once at a concours when the Freaking Judge tried to open the locked passenger door.
    DM
  5. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    The cable cam may be rotating on the threaded shaft. It may not be the cable slipping on the cable-stop. Simply removing the panel, finding a good light, and studying the mechanics will solve the problem. Study it until you understand everything, and then study it again. It is very simple once you see how everything works.
    The shaft attached to the chrome outside latch may be bent, or the sleeve going through the door skin can be crimped. If you really want to do it right, remove all of the parts (a weekend afternoon project), study them, and reassemble.
    Jim S.
  6. Yves Delhaye
    Yves Delhaye Rookie
    Apr 3, 2008
    25
    France
    Thanks to all of you for these suggestions.
    Yves.
    France.
  7. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    I have a similar problem. Passenger door sometimes closes perfectly, sometimes it is not in line with rest of body (not fully closed), and it has swung open once. The interior lock button sometimes goes up and down smoothly, and the door closes when the lock button is working, but sometimes the lock button will just freeze, and then you need to put just a bit of force on the door to close it. I'm wondering where is the easiest place to start? If that doesn't work I'll remove the door card and study the mechanism.
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Jim knows - Word of wisdom, let me add a photo which may make it more clear
    At the base of the handled shaft is a cam with cable stop that feeds the cable through a small pipe to the lock pivot. There are two common adjustments;
    1) cam position and
    2) cable tension
    If you love to squirt lubricants down that shaft they may end up on your jam nuts and easing their fastening ability. Clean and tidy with light grease is a far better way. Always remember that the cam is giving you a mechanical advantage, so be gentle when pulling on the door handles. Unlike tennis, you do not want to follow through on each stroke.
    The interior door handle is connected to a different and separate pivot in the lock system, so it is normal to act indepoendent and not be affected by your problem
    Your situation sounds different. From an armchair "guess" and not seeing the door, this appears to be a door alignment issue. The catch is a two stage take up with the striker and from what I read, you are only tripping the first stage.
    Your issue of the door lock knob could be a positioning from rear of lock cylinder or connection. Are all of your plastic rod clips still unbroken? If not you'll need a clip for an 8.5mm hole and a 5mm rod, tyipcally 1990s Toyota truck or Lexus use these, the yellow in the photo
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    This is a separate topic from the above handle issue, I can think of two reasons why the lock button freezes
    1) misalignment with key cylinder rod (highly unlikely, huge slop there)
    2) Return arm obstruction - striker may have only partially engaged; closing the door only moved past one of the two ratchet clicks
    Completely arm chairing this without seeing the car, yours sounds like a door alignment issue causing incomplete striker engagement as indicated by the lock obstruction. Kneel down to about lock level then open and observe the door closing slowly. Look closely for the striker centering as the alignment post nears the receiving hole. You want everything to line up. If that post is "ramping up" on contact then you have found something. There are four M6 screws on the striker base that allow it to be free to move around to fit the post. Loosen these and align. You will probably do this 3 times before you are happy with how it looks so do not be worried if your first try is an almost.
    If that doesn't work, then there may be a search for sag in the hinges, but that is just so negative a topic we shouldn't go there yet
