Problem with driver ergonomics in 812 (extend steering wheel?) | FerrariChat
Discussion in 'F12/812' started by blabus, Aug 30, 2020.
  1. blabus
    blabus Rookie
    Nov 28, 2018
    42
    San Francisco, CA, USA
    I just picked up my first Ferrari, a 2018 812 Superfast, and it's been incredible so far. The one issue I've run into (which for some reason I didn't notice on the test drive) is that I can't seem to find a comfortable seat/steering wheel position. The steering wheel doesn't extend far enough towards me, which results in my having to slide the seat forward so my arms are a comfortable distance to the wheel, at the expense of my legs being very cramped up (or vice versa, sliding the seat back far enough so my legs extend more comfortably results in the wheel being too far away/my arms being too outstretched for my taste).
    Has anyone else run into this issue? Is there any possible way to extend the steering wheel/column farther (maybe a spacer of some sort)? Or even push the pedal box farther back (I have to assume that's impossible)? I'm 5' 9" so I wouldn't consider myself to be abnormally short or tall, so I feel like I'm missing something as far as why I can't get comfortable in this car.
    Thanks for any help!
  2. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,181
    Denmark
    Max
    I think it's a common issue with Ferraris... It looks like Italians have longer arms (or shorter legs...)
  3. Napoli
    Napoli Formula Junior
    Nov 18, 2017
    958
    NOYB, Ray!
    Yeah, they could've done better. I like to sit as low and as far back as the seat will allow (wish it were more). But, if I lower the steering wheel to a position that best accommodates me, the wheel blocks the mid to upper view of the tach. So, as to have nearly full view of the tach, I'm forced to drive with arms extended at shoulder height. Same with my 488.
  4. wrs
    wrs F1 World Champ
    13,916
    Lakeway, Texas
    William
    I have long arms and legs, no problem for me.
    SeattleStew likes this.
  5. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    Do your legs extend all the way to the ground? I find that helps.
    Il Co-Pilota and ryalex like this.
  6. SeattleStew
    SeattleStew Formula 3
    1,019
    In the rain
    Stew
    I guess you might be just in the right (wrong) size proportions for the car? I’m 6’4” and have been able to get my seat and wheel into a perfect spot. My fiancé is 5’4” and is also able to get it just right for her.
    I actually have 2 seat positions saved in. 1 for more sporty upright position, and 1 for more leaned back relaxed on a multi hour drive. I will say, I wish I could get the seat back maybe 1 more inch in a perfect world.
    Might be worth trying to find a position with tilting/raising or lowering the base of the seat to help adjust your legs?
    wrs likes this.
  7. Jljr
    Jljr Rookie
    Feb 25, 2018
    49
    Miami Beach
    I’m 5-9 and car has all electric seats, no issue in adjustment; maybe limited adjusting racing seats your issue?
  8. blabus
    blabus Rookie
    Nov 28, 2018
    42
    Hmm nope, I have the full electric seats.
  9. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    181 and no problem. Could you measure the distance from the wheel to your chest when that distance is as you would like it to be?
    Also, at what angle is your elbows if you put the seat so that your legs are where you would prefer them to be?
    How tall are you?
