PROBLEM WITH WHEELS SPACERS | FerrariChat
Discussion in '348/355' started by brancati66, Aug 31, 2009.
  1. brancati66
    brancati66 Rookie
    Aug 31, 2009
    36
    Italy
    Hello everyone, my name is Louis and I write from Italy (Puglia-Bari). It 'the first time that I write on this chat that I find very comprehensive and interesting.
    I extend to you a question: I have mounted on my 348 TB of 1989 (with original wheels) 20 mm wheel spacers on the front and on the rear. To the rear no problem but when the front wheels are steered completely and there is a roughness or a bump on the asphalt, the wheels touched under the fender. How can I fix this? Thank you all. Forgive mistakes. Regards.
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    I think your front spacers are too thick ........ the common size 348 owners use on stock wheels is 15mm front and 25mm rear .......... Ricambi sells them and they are top quality :)
  3. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    I had 15mm fronts on mine and still managed to dent the wheelarches on occasion. Had to keep a hammer and a lump of wood in the 348 so I could whack it out.
    In the end I had the front wheel arches rolled.
  4. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    +1
    20mm front is too wide.
    Kai
  5. Ricambi America
    Sponsor Owner
    +1
    Maximum on the front of a 348 would be 15mm -- and only works if you have a very squared-shoulder tire design (P-zero is pretty squared).
    11mm is more common and less likely to rub.
