Problems putting RE71R on CS | FerrariChat
Discussion in '360/430' started by inflectionpt, Jul 8, 2019.
  1. inflectionpt
    inflectionpt Rookie
    Jun 5, 2014
    30
    Just got a call from my tire shop that they can't seem to make the 225/35/19 RE71Rs to hold air. Has anyone run into this issue? First time changing tires on the CS and had no idea I would run into this problem. TIA.
  2. chnco
    chnco Formula Junior
    Dec 20, 2014
    464
    Atlanta, GA
    Allen C
    There is a special procedure to fill a CS Tire with air, you must ensure the halogen fluid is topped off.
    I would go to a different tire shop.
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    No I think it is the blinker fluid or check your tag bolts
  4. jcurry
    24,092
    In the past
    Jim
    Not with RE71Rs, but I have had tires (Hoosiers) that the bead did not set well and had a slow leak. I imagine your tire shop knows all the tricks to try and correct, but it may be the tires themselves. Hope you get it sorted.
