Problems with 1-4 cyl. Not working at all | FerrariChat
Discussion in '348/355' started by Leonas, Nov 3, 2011.
  1. Leonas
    Leonas Rookie
    Feb 19, 2011
    36
    Vilnius, Lithuania
    Leonas
    Hello,
    Have some problems with right bank cylinders (1-4). They just stopped working...
    I've checked the ignition coils - doesn't have a spark there. Not sure if fuel injectors are opening too.
    I thought that I have problems with blown ECU, but tried to change ir with the left cyl. bank ECU - nothing changed. Left side was working as before, right side still 'dead'. Disconnected the plug from ECU, tested if I have power supply. Yes it has. Although the right ECU had one more extra cable with power supply. Strange...
    Some additional and interesting info: then I try to start an engine (turn key to the ignition pos.) on the dashbord I can watch only the 5-8 CEL ans 5-8 slow down lights turning on. It seems like that the right bank ECU is 100% dead, but it isn't...
    And some more extra info: then I was going from my place to repair shop all 8 cyl. started to work for few minutes (turning the 5-8 CEL on for few seconds). Opened the engine lid, closed and again 4 cyl there gone...
    I've tested in car allmost all sensors directly and it seems that all are working properly.
    Without detailed repair manual (with wiring diagrams) I can't find what and there I can check. There can I find these manuals?
    Now car works only on 4 cyl... Have some suggestions?
    Sorry for my english... It's not my native language ;)
  2. sdbmwfxr
    sdbmwfxr Karting
    Feb 25, 2011
    238
    San Diego
    Try swapping main relays
  3. Leonas
    Leonas Rookie
    Feb 19, 2011
    36
    Vilnius, Lithuania
    Leonas
    floor fuse and relay box?
    Been there... done that...
  4. plugzit
    plugzit F1 Veteran
    7,794
    Redondo Beach, CA
    Bruce Bogart
    348 or 355?
    Sounds like a bad connection somewhere or a bad wire.
  5. Leonas
    Leonas Rookie
    Feb 19, 2011
    36
    Vilnius, Lithuania
    Leonas
    #5 Leonas, Nov 3, 2011
    f355. 2,7 motronic.
    I'm thinking about bad connection too, but there shood I start? I guess I should check underneath the floor fuse and relay box?
    But it's a little bit strange that on the cable (to ECU) plug I have all the power supplying cables (even one more then at left side ECU's plug)... And still don't have working ECU...
    Edit: HELP!!! I haven't done any km's/miles in 7 past days - I'll fall in depression if another 7 days will past the same... :D
    I need to drive this car of perfection!
  6. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    Crank sensor???
  7. Leonas
    Leonas Rookie
    Feb 19, 2011
    36
    Vilnius, Lithuania
    Leonas
    Tested only the resistance; almost the same - the difference was only in few ohms. Tomorrow i'll check the whole signal with engine running.
  8. fatbillybob
    Aug 10, 2002
    29,274
    socal
    It has been a long time for me with 348's. There is a screw in plug above left shock tower area just under that flat part where you would most likely park a tool when you are working on the car. Also check ground to the valve cover right under the fuel rail on effected side. 10mm hex nut about 1/4" black wire.
  9. crazyspeed
    crazyspeed Karting
    Aug 11, 2011
    50
    If there are 2 coil wires...probably a bad coil wire on right bank?
  10. plugzit
    plugzit F1 Veteran
    7,794
    Redondo Beach, CA
    Bruce Bogart
    Swap coils side-to-side, see if it changes. Then do igniters the same. Igniters are sometimes a problem, and can be periodic as you described. Good-lookin' car!
  11. Leonas
    Leonas Rookie
    Feb 19, 2011
    36
    Vilnius, Lithuania
    Leonas
    been there, done that... nothing changes... Thanks for advice.
    I'll check it as soon as possible. Thanks
  12. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    From this description you could have a bad catalytic converter temperature ecu, or a bad thermocouple. Try disconnecting the catalytic converter ecu from the main wiring loom and see if the "dead" bank fires.
    That's my guess.
  13. fatbillybob
    Aug 10, 2002
    29,274
    socal
    I thought the OP had a 348. But looks like 355 2.7 motronic. If like the 348 then the exhaust ECU (aka slow down ECU) disconnect will not throw a CEL like on 2.7 348's. It is the 5.2 motronic (shared with the 550) that looks for the SDECU and will throw a code and MIL.
  14. Leonas
    Leonas Rookie
    Feb 19, 2011
    36
    Vilnius, Lithuania
    Leonas
    #14 Leonas, Nov 22, 2011
    Problem solved. Bad connection in the fuse box. Soldered every connection in fuse box and checked all the wires.
    Thanks for your advices!
