Problems with TCU | FerrariChat
Problems with TCU
Discussion in 'Technical Q&A' started by 3s-ge, Mar 15, 2018.
  1. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,229
    Georgia
    Wade Williams
    It's a stick shift car?
    Sorry, I am just kidding. I have done that before on a full inspection of a car. Took a few seconds to realize why I could not connect.
    What car is it and what is the actual issue you are looking to diagnose?
  3. eric355
    eric355 Formula 3
    1,233
    Toulouse (France)
    Eric DECOUX
    Not all the tools can connect to the early TCUs ... even if they advertise so !
    Don't you have a TEXA ?
  4. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    F360
    Check the wear of clutch and calibration after change
  5. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    Maxisys 908pro
  6. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    As can you see the tool with support first generation of tcu
  7. eric355
    eric355 Formula 3
    1,233
    Toulouse (France)
    Eric DECOUX
    Which TCU do you have ?
    Have you already connected the tool to your TCU before, or is it the first try ?
  8. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    First try...
    P/n 176552
  9. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    That scanner, and the X431 will not access early TCU
  10. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    First generation!
  11. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    That is the ONLY thing it does, cannot read or change settings. I have tred on a lot of 360, have to use my Leonardo for those.
  12. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    I can't do this...
    I can't to connection to tcu...
  13. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    what kind of ecu need to install to car for work with it?
    • 185301
    • 185741
    • 189542
    • 191701
    • 193263
    • 195399
    • 197533
    • 211023
  14. eric355
    eric355 Formula 3
    1,233
    Toulouse (France)
    Eric DECOUX
    You should be fine with any 360 TCU with ref higher or equal to 191701 ... including the CS TCU (196986)
  15. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    I still don't understand... I have 1st version and on YouTube 1st version, why I can't to conection? maybe problem not in a ecu?
  16. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
  17. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    That is actually the second version then 3rd version on the Autel, as Eric says, upgrade the TCU and it will be fine and better. BUT make sure the clutch settings are recorded or if you self learn, it will give hard shifts or a flare between shifts.....and you may need to input the new numbers.
  18. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    can you input clutch values into the latest 2004 generation TCU with the Maxisys 908pro? PIS etc?
  19. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    I bought a CS TCU from Eric, thank him for it.
    And soon I'll check can i change the PIS or not
  20. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Received a reply from Julia at Autel. The system currently that is capable of reseting codes: MaxiSys Pro MS908P J2534. Appears Autel developed a code interface tool J2534 that works with the latest generation software.
  21. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    lies!!!!
  22. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Interesting! Good friend and top rated pro confirmed your experience.
  23. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    give him the link to this chart, let them comment it
