Problems with TCU | Page 2 | FerrariChat
Problems with TCU
Discussion in 'Technical Q&A' started by 3s-ge, Mar 15, 2018.
  1. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
  2. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
  3. tbakowsky
    Sep 18, 2002
    20,067
    The Cold North
    Tom
    From what I remember, the PIS setting is not adjustable on the early ecu,s. 1999 and 2000 cars. You can however play with the clutch index or the new closed clutch index. This is the setting to get the car shifting nicely.
    The PIS should self learn by following the procedure in the manual. Then drive it and see if other adjustments are needed. Don' start throwing random numbers into the ecu. Make sure you know how to do this, or you will be installing another clutch before you know it.
    Qavion likes this.
  4. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
  5. 3s-ge
    3s-ge Karting
    Jun 23, 2012
    222
    Alex
    at 4.6 the gear behaves badly.
    At 5.0 better but gear is switched with bang
    5.4-5.5 - ok
  6. 24000rpm
    24000rpm F1 Rookie
    interesting, Lisa叶。 i want to talk to him/her about compatibilities
  7. jg360
    jg360 Formula Junior
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    I also have the Autel 908 and can not change the PIS. I can’t find where to change the clutch index
