Procedure for Checking Oil Level | FerrariChat
Discussion in 'Boxers/TR/M' started by ronc123, Jul 6, 2025.
  1. ronc123
    ronc123 Karting
    Jan 12, 2008
    80
    Southern California
    Ron
    I have a new-to-me 1990 Testarossa, USA version. I have read the owner's manual on checking the oil level and comments in this section. Does the following step-by-step procedure mirror what owners do to check their oil level? Your comments are most appreciated.
    1. Car is warmed up and running at temperature.
    2. Turn car off and quickly open the rear deck lid.
    3. Unscrew the oil filler cap and wipe the dipstick clean with a rag.
    4. Insert the oil filler cap and screw it back into place.
    5. Immediately unscrew the cap and ensure that the oil level is within the min/max level.
    6 Screw the cap back in and you are done...
  2. lagunacc
    lagunacc F1 Rookie
    4,330
    Yes. When cold that corresponds to the bottom of the dipstick.
  3. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    265
    Southern Florida
    Ron, a finer point is NOT to keep your oil level near the max. Search crankcase ventilation on this forum. EDoug
    Rifledriver and Threeofnine like this.
  4. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,602
    Pacific NW
    Anthony C.
    I have also been taught that with dry sump engines; you should check oil level while the engine is running. This poses a little more risk with front engine cars but in the case of the Testarossa series, not so much since you can access the dip stick to the reservoir from the side.
  5. Threeofnine
    Threeofnine Formula Junior
    Dec 11, 2020
    393
    Birmingham, AL USA
    Jarrod Heath
    You’re not supposed to keep the oil near max? What is a good level, maybe halfway? I tried searching crankcase ventilation but nothing popped up. Could you link a thread?
  6. Rifledriver
    37,050
    What you should have been taught is to do it the factory way. Ferraris way is NOT with the engine running.
    bernieb likes this.
  7. Rifledriver
    37,050
    The car holds 3 1/2 gallons of oil. A quart or 2 low means nothing. Overfilled is a disaster.
    Dont even consider checking it below 170-180 degrees. Warmed up means oil temp, not water temp.
    Dont bother screwing cap on while checking.
    bernieb, ago car nut and Threeofnine like this.
  8. ronc123
    ronc123 Karting
    Jan 12, 2008
    80
    Southern California
    Ron
    I followed the oil checking procedure I outlined in this post. When I checked the oil level, it was about 2 millimeters above the MIN mark on the dipstick. Should I add a half quart of oil, or even a full quart? How many quarts of oil between the MIN and MAX marks on the dipstick? What is the recommended oil to use? Thanks.
  9. Steve Magnusson
    26,732
    MIN to MAX is 2 liters (or 2.1 qts) -- see "Lubricants and Liquids" in Section 1 of your OM. Put 1 qt in and call it good.
    turbo-joe likes this.
