Process for Replacing 355 AC Control Panel Laminated Surface | Page 2 | FerrariChat
Discussion in '348/355' started by Dr Dave, Dec 17, 2006.
  1. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    ...oops sorry ..... yes those three bulbs are a bit bright for the replacement overlay sharpie those and it should look perfect :). The overlay is not as opaque as the factory 'bubble' panel..... ;)
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    OK, I did it with a "Nero" Sharpie :) :)
    Hope it works
  3. f355spider
    f355spider F1 World Champ
    18,055
    Which products are you finding works the easiest for cleaning?
  4. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I used 70% isopropyl alcohol, (rubbing alcohol) and Kleenex, worked really fast.
    Q-tips to get in the recesses.
  5. Dr Dave
    Dr Dave Karting
    Dec 11, 2006
    62
    Northern Virginia
    Dave Kirk
    I used a product recommended by my mechanic at the Ferrari dealership - called 'Spray Nine' (available at Lowes). Others have used oven cleaner, alcohol, and all kinds of other products.
    The Spray Nine worked and as many of my posted pictures show, I got great results. However, it was NOT fast. I spent hours each night working on switches and such. So, if others are getting this gunk to 'just fall off' in a few minutes - try what they used! I spent at least a week working several hours a night.
    It's FANTASTIC having the car all cleaned up and the A/C Unit replaced... this is how a Ferrari SHOULD look.
    Cheers,
    Dave
  6. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    I have tried just about every type of cleaner available, and by far the easiest and most effective was Isopropyl alcohol.
  7. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1
    I have not tried that many but I ended up using iso-alcohol :)
  8. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    I have found different levels of stickiness require different products. I have used everything from Lacquer Thinner, alcohol, Easy Off, degreasers, etc.... Depending on the condition of the part is what I use.....
  9. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So from your post...... I deduce the lacquer thinner and easy off don't melt the plastic ...... :eek: .................... I may have to try some of those when I need to do more parts, thanks :)!
  10. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    Great work, I followed Dr Dave's excellent instructions and got Daniel's great replacement sticker and that part of my 355 now looks like new. Thank you all.
    Now the switches and surrounds of the brushed aluminium F1 reverse lever look shabby, as well as the air vents in the dash.
    Would you mind telling me the correct procedure for removing them for cleaning without stuffing them up?
  11. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    Was it a hard question? Only joking I just wanted to bring this back up the list in hope of getting an answer.
  12. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    #37 hank sound, Jul 2, 2008
    Yes folks,
    Upgrading and converting is a challenging task. Imagine changing a RHD 348 to a LHD 355 !!! OMG - the amount of work involved :) But Dottie, my cat, was thrilled to see that this conversion at least corrected an often overlooked item. Why is it, that people who should know better, consistantly mount 348 wheels improperly???!!@#$ - Oh well.
    But, back to the jist of this thread - - I'm amazed at the beautiful results of what must certainly be a huge amount of precise, measured handiwork. Great work, guys.
    Cheers, Hank
  13. 285ferrari
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    Are you asking how to take everything apart? Or how to get the switches, vents, etc out of the car?
  14. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    How to get the switches and vents out without damaging them.
  15. poldi99
    poldi99 Rookie
    Mar 29, 2008
    12
    wow, i´m impressed. it looks really very good!
  16. AFASTA1
    AFASTA1 Rookie
    Jun 4, 2008
    37
    Montclair NJ
    Jeff
    can anybody tell me about using soapy water when applying the new decal? i got the part from Ricambi but no instructions. what kind of soap? how much soap to add to how much water? hot water? cold?
    thanks
  17. Aiden
    Aiden Karting
    Mar 13, 2009
    217
    Huntington Beach, CA
    Aiden Naughton
    Great thread! I would think Eazy Off would be too harsh for the plastic knobs, is that the ticket though? They look amazing.
  18. 285ferrari
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    Instructions are on Ricambi's website
  19. 285ferrari
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    Wouldn't be cost effective when the panel can be refinished for much cheaper. Even if an overlay is made, the shifter plate would have to be stripped of all the old coating to stick properly.....
  20. 285ferrari
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    DO NOT use lacquer thinner unless you use it VERY carefully, it will melt plastic. Trust me...:D
  21. 285ferrari
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    All depends, I judge the finish when I receive parts and that determines which product I use to strip it. Some guys here will tell you certain products work very easily. And on some cars they do, but trust me not every part is the same. Back in the day I used Easy Off on one part and it came off fairly easy. The next part I tryed, Easy Off wouldn't touch it......I have made my own blend of stripper that works pretty well on almost any part now.....
  22. AFASTA1
    AFASTA1 Rookie
    Jun 4, 2008
    37
    Montclair NJ
    Jeff
    yes, the instructions i saw on the ricambi site are the same as the original post by Dr. Dave in this thread. but i couldn't find any specifics about how to apply the liquid soap without ruining the decal. eventually i heard back from Daniel at Ricambi. here's what he recommended:
    "i'd use a 5:1 dilution (water:liquid soap)-- and a VERY light mist onto the panel. You'll have a few seconds to reposition if necessary."
    i used liquid dishwashing soap in lukewarm water and it worked fine. i had no mister or spray bottle so i used a cotton swab to wipe some of the solution on the face of the control panel, not on the decal. then i applied the decal and had about 12-15 seconds before it got sticky. it came out great!
  23. 285ferrari
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    I mix about the same dilution with Dawn and water in a spray bottle and shake it up real good before spraying. Spray a mist all over the sticky side of the overlay and lay into place. Get it in a good position and place under the heatlamp for 2-3 minutes. After that it is good to go....Next!!!
  24. 285ferrari
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    Did you refinish the 3 knobs?
  25. Dr Dave
    Dr Dave Karting
    Dec 11, 2006
    62
    Northern Virginia
    Dave Kirk
    Well, I'm coming out of my 'black hole' one divorce and household move later - it's been about a year since I've been out on FerrariChat! Glad to see this thread is still alive and well.
    With regard to the soap, following any of these directions should work fine. I honestly just mixed some dish soap with water and didn't even worry about ratios and such. It just has to be enough soap such that the water creates the 'slippery effect' when you are applying the decal. If I remember correctly, I actually put the soapy water on the plastic surface, but I'm sure spraying the decal has the same effect. You just need to buy yourself a few seconds to get it positioned right, so there is no need for much more than a mist - that way it evaporates quickly and sets in place without moving around too much.
