Project 355: ... New Robust Bypass Valve Design ... Rattles and Buzzes NOT Included!! | FerrariChat
Discussion in '348/355' started by gothspeed, Jun 10, 2016.
  1. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    #1 gothspeed, Jun 10, 2016
    Most 355 owners are unfortunately very familiar with the rattle and buzz prone OE bypass valve. Either on their own 355, someone else's or from reading about it on this forum ...... my 355 was no exception to this malady :eek: .... so as many other 355 owners have done ..... I first added tension 'turns' to the actuator linkage ..... worked for a bit ... noise came back ... then added an external spring to preload the shaft at center slightly .... worked for a little longer ..... noise came back ..... sourced a 'good used' bypass (not as worn) ...... worked a little while ... now the noise comes and goes ..... :(
    Should I buy a new one and wait for that one to fail as well? Nope! .... enter the 'goth' solution to this nagging problem .... a New Robust Bypass Valve Design to replace to OE unit ... Rattles and Buzzes NOT Included!!! :)
  2. k17har
    k17har Karting
    Sep 3, 2009
    144
    london, uk
    kayer
    That looks beautiful and wonderfully done! Top man :)
  3. plugzit
    plugzit F1 Veteran
    7,784
    Redondo Beach, CA
    Bruce Bogart
    Schweet!!!!!
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    100% BADASS!!!!
    That is fricken beautiful!!!!!!!!
    Oz my man, once again you have done a brilliant job!
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Looks great!! I like the quilt too :)
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,781
    Lake Villa IL
    Very nice!!!!
  7. malex
    malex Formula 3
    1,247
    FL
    Looks very nice! How does it compare to the Capristo bpv?
  8. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Where does the vacuum pipe attach, on the side like OEM? Thats my only gripe with the Capristo version that I have. Would much prefer the vacuum tube to attach on the side rather than the top.
    Looks great.
  9. ShineKen
    ShineKen F1 World Champ
    19,901
    Southern California
    Nostradamus
    + 355
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,244
    CT
    John Kreskovsky
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #12 gothspeed, Jun 10, 2016
    Thanks for the good words .... :)
    I looked at internet pictures of the cappy bypass valve and there were a few features I didn't like .... the butterfly itself has portions of the shaft welded on each end .... which leaves the thin butterfly plate to itself hold shaft/bearing alignment. I believe this was done to compensate for the flow reduction of the rather large butterfly plate 'stops', which are cast into inner wall of the housing (see cappy bypass pic below). However I am not certain if cappy still makes them this way.
    The goth bypass valve uses a genuine Pierburg vacuum actuator (same brand as OE) ..... so it has the vacuum connection on the side of the canister ... :)
    capristo bypass valve pictured below vvv
  13. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Great job then! When are you selling them?
  14. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,169
    So. CA & NV
    Peter
    Looks great!
  15. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Looks nice Oz.:)
  16. phrogs
    phrogs F1 Veteran
    7,348
    Kzoo Michigan
    So how much are you thinking for these..
  17. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1
  18. baschul
    baschul Karting
    May 27, 2015
    177
    Dallas, TX
    Brian S
    +355
  19. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    $1mm meeellion dollars.
  20. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Elegant... Is there a gold version? :)
  21. WATSON
    23,723
    WI
    Dear Mr. Goth,
    It appears that you have a very nice prototype product. I would be willing, at no cost to you, to test that product for a period of 12 months. I can provide monthly feed-back on the performance and usability of that valve. I can even send some pictures if you like.
    Anything to help the brotherhood.
    Let me know when they become commercially available. I like it.
  22. ssnowball
    ssnowball Formula Junior
    295
    Scot
    You know I,m in, going to have to put a goth or oz logo under my shields to acknowledge your input to my car...
  23. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Man, that is some gorgeous engineering. Are you offering them through Ricambi? Also, what makes these more robust and not prone to buzzing? It is beautiful, looking very very expensive. :)
  24. BucksTifoso
    BucksTifoso Karting
    Nov 24, 2013
    91
    Furlong, PA
    Randy Crownover
    Does the bypass valve noise sound like a rattling chain? I hear an intermittent noise that sounds like a metallic chain coming from the left rear? of the engine.
  25. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    I see what you did there. Funny boy, fuuuuuunny booooy.
