Project Stratos | FerrariChat
Project Stratos
Discussion in 'Other Italian' started by Zarathustra, Jun 27, 2022.
  1. Zarathustra
    Zarathustra Formula Junior
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    MK1044 likes this.
  2. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,517
    Metro Detroit/Encino
    Steven
    Thanks for posting. Really cool car. It's tailor made for Kanan or Mulholland. :)
  3. kens
    kens Formula 3
    1,335
    This was Toly Arutunoff's car. I saw him use it in anger way back when, on his Hallet track.
  4. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    Glad to hear she was thoroughly enjoyed... Next?
    The one interesting accouterment I noticed on her was the cross-ram intake manifold.
    The discerning eye will notice the carbs are set at about a 45-degree angle to the crank, unlike a standard Stratos/Dino which has the carbs @ 90 degrees.
    This is a competition manifold, with longer intakes, which cross from one side of the engine to the other. and can accommodate larger Webers.
    (My old 001882 had the same) The throttle linkage is different, especially trick with the hand throttle.
    This is only useful if one ports&polishes with larger valves and installs a larger exhaust manifold (which 001559 has.)
    Back in the day, Toly made this a brutal beast, put a lot of money in her.
    I'm not quite sure which way a restoration should be approached....
    Thoughts?
    MK1044 likes this.
  5. staatsof
    95,935
    Fuggetaboutitland
    Bob
    boxerman likes this.
  6. nis1973
    nis1973 Formula Junior
    Jan 19, 2013
    493
    NYC/CT
    Yes, there seems to be a fair amount of rust in all sort of places. Hard to tell if it's just surface rust...
  7. staatsof
    95,935
    Fuggetaboutitland
    Bob
    Those pedals look atrocious, kind of sad. Rode hard and put away wet, perhaps last in the salty snow?
  8. GIOTTO
    GIOTTO F1 Rookie
    Dec 30, 2006
    3,915
    France
    staatsof likes this.
  9. racerboy9
    racerboy9 F1 Rookie
    2,642
    Zarathustra likes this.
  10. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    Beautiful intake manifold photos!
    This set-up obviously mandates using a non-stock air cleaner housing
    Here is the solution on 001882, which still allows the stock rear clamshell and Muira vents.
    GIOTTO, thanks for the period photos! She still looks unmolested in 1977.
  11. GIOTTO
    GIOTTO F1 Rookie
    Dec 30, 2006
    3,915
    France
    NürScud likes this.
  12. nis1973
    Jan 19, 2013
    493
    NYC/CT
    Apparently the engine currently in the car is from a Fiat Dino 2400 (spotted by my eagle-eyed go-to Stratos expert). He gave me a long list of other non-original (in many cases non Lancia) bits based on the photos on the RM site. Will be interesting to see the full catalog description once it's out. He also said that there was another Stratos competing in IMSA in period, driven by a Frank Bonfiglio (he did some work on it back then).
  13. racerboy9
    racerboy9 F1 Rookie
    2,642
    The louvered vents on the GR4 cars were hinged so they could be raised and used stand-offs to set the height to clear the air cleaner.
  14. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    The old girl got $566k. Not bad for a project that needs another $200 to $300k.
    Thank you to whoever bought her!
  15. nis1973
    Jan 19, 2013
    493
    NYC/CT
    Yeah, I was the underbidder so a bit bitter. It’s going to the right home, though, to someone who’ll do right by it…
  16. Zarathustra
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    Girardo & Co. ended up with this project Stratos. Very brave!
    https://girardo.com/features/
    johnei likes this.
  17. nis1973
    Jan 19, 2013
    493
    NYC/CT
    Yes, I guessed that much a couple of days after the auction and confirmed with them.
  18. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,659
    NOLA
    Chris
    Now you can buy it when they finish and save yourself the headache.
