PTU leak | FerrariChat
PTU leak
Discussion in 'FF/Lusso' started by cromwrima, Sep 7, 2023.
  1. cromwrima
    cromwrima Rookie
    May 31, 2023
    37
    I know, I know - another PTU thread, but this time it might be slightly different...
    So, to summarise my 2011 FF has around 50k miles and as far as I know the PTU has never been done.
    I've owned it for 3 months, and after 2 months the 4WD system failure message started appearing, along with manettino failure, low 4WD ATF oil pressure and the car being stuck in Wet mode.
    I know about the PTU and had researched extensively before buying but knew I'd probably have to stump up the £9k for a rebuild here in the UK, so assumed it had gone kaput.
    I took it back to the dealer I bought from for diagnosis, and they had it for a while and said it was leaking externally from the supply hose which they changed and it appeared to be OK. The return pipe had already been changed by the same dealer earlier on in the year prior to me buying it.
    So both PTU hoses have been replaced, but after leaving it for a few days the garage said there is still a small amount of ATF fluid leaking somewhere near the PTU.
    My question is are there any known weakpoints for external PTU leaks? The garage mentioned where the PTU connects to the diff but that doesn't seem right.
    Any suggestions based on the diagram below taken from Eurospares?
  2. sandman03456
    sandman03456 Formula Junior
    389
    Las Vegas, NV
    Check the reservoir hoses (#10) and the white refill reservoir (#6) for leaks. I have heard of these cracking which can result in a leak?
  3. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,746
    Weston, MA
    Paul
    I'd take it back to the dealer and have them check the connections for the hose they replaced.
  4. cromwrima
    cromwrima Rookie
    May 31, 2023
    37
    Thanks dude will pass it on. They're talking about having to drop the transmission so I hope it's something simple.
    It's with them there now
  5. ttforcefed
    ttforcefed F1 World Champ
    19,230
    never simple with a ferrari
  6. cromwrima
    cromwrima Rookie
    May 31, 2023
    37
    Ok some seals have been ordered apparently and that should fix the problem, although like our esteemed comrade ttforcefed said, nothing is ever simple with Ferrari. I doubt that this will be the last of it.
    Also the outside temp sensor is faulty (the one on the door mirror) and reads 50c at all times and is also causing an EML! I swear Italians do these bizarre things on purpose just for a laugh and to mess with people :D
    papou and ttforcefed like this.
  7. belfry
    belfry Formula Junior
    May 14, 2015
    474
    Robert Batt
    Will you replace the outside temperature sensor? It’d be interesting to see if it fixes the EML.
  8. cromwrima
    cromwrima Rookie
    May 31, 2023
    37
    Yes, it should do as I've read from several sources (and the garage doing the work) that the temp sensor is linked to the TPMS, climate control and ECU.
  9. cromwrima
    cromwrima Rookie
    May 31, 2023
    37
    Just as way of an update, the secondary leak was located, sealed and the PTU is working once more as it should.
    I'm not sure exactly where the leak was but it was described as where the PTU connected to the engine block. The PTU had to be removed and a seal replaced.
    All covered under warranty from the garage I purchased from so pretty happy with the outcome, although I'm still pretty sure the actual PTU itself will need a full rebuild at some point as I'm at 50k miles.
    ernie, ANOpax and ttforcefed like this.
  10. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Yes, this what doing SSAutotech, but in your case it's only temporary solution, because stock seal ring is weak part there, and also SSAutotech installs modified forks in PTU.
    ANOpax likes this.
  11. papou
    papou Formula 3
    1,720
    plantation Fla
    daniel ross
    I must believe that Ferrari hasn’t cured this fault especially with the release of the P/S.
    ANOpax and Nospinzone like this.
  12. Viper830tt
    Viper830tt Karting
    May 10, 2017
    157
    Regarding "warranty" would PTU failures or anything short of that be covered under the power warranty?
  13. Nospinzone
    Jul 1, 2013
    7,746
    Weston, MA
    Paul
    I had a burst oil line to the PTU and had it repaired at a Ferrari dealer. I did not have the Power Warranty, but I asked the service manager if it would have been covered. He told me it would not.
    When my FF came off warranty I asked about the cost of the Power Warranty and was quoted $8700 plus inspection. So I've been self-insuring for 4 years and I'm way ahead of the game. :cool:
    ANOpax likes this.
  14. Viper830tt
    Viper830tt Karting
    May 10, 2017
    157
    Interesting. I'm usually against warranties but this may have been one area where I would give in. Ive been doing the same with my 458. One clutch sensor repair for $9k but still out ahead for the years used.
  15. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,175
    Denmark
    Max
    I was going through exactly the same questions a year ago when came the time to extend my warranty. I saw that the Power 15 did not cover seals or leak. So I thought it would not cover the typical PTU failure where the seal between the transmission oil and hydraulic oil is made, and decided not to take it. Havent had any issue since Im out of warranty so it looks like I might have made the right call.
  16. ak4713
    ak4713 Rookie
    Sep 28, 2023
    19
    Central NJ
    #16 ak4713, Oct 27, 2023
    For reference and hopefully helps someone with decision making- this is what the power warranty documentation says (excuse the formatting with copy paste from pdf)
    COVERAGE
    The Program covers functional defects of the vehicle with the exceptions set out in Paragraph2 of" Terms and conditions of Ferrari "Extended CoveragePlus* Program and in Paragraph 3, "Exclusions*,below
    3. EXCLUSIONS
    3.1 The formula does not coverfaults resulting from normal wear and tear of the vehicles, and specifically: Brake discs; Brakepads;
    Battery; Spark plugs; Oil, fuel and air filters and other consumable items; Complete clutch (disc and pressure plate); Tires;Ancillary
    belts: Windshield wiper blades; Active-carbon filter;Airconditioner filter,AC refrigerant, Labor relative to the aforementioned parts;
    Theformula also does not cover: Non-Genuine parts or accessories installed by the Dealer;Wheel alignment/suspension settings; Corrosion to box section elements;Normal noise, vibration and wear ofparts; Deterioration of leather and interior upholstery caused by normal wear and
    tear or through treatment not in accordance with theOwner's Manual.; Minimal noise,Infiltration via seals between roof and bodyshell or via door windows. For these cases, please consult the guidelines given-in the Owner's Manual; Labor relative tothe aforementioned
    components and/or defects.
    ver.02 2022
  17. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Because dealers is terrible, that's why. For that price they asking, there are should be work high engineers from Germany
  18. 2006m5
    2006m5 Formula Junior
    Dec 19, 2008
    923
    huntingdon valley PA
    Sorry to hear your issues…but iam amazed there isn’t a way to take out this system and run the car as RWD.
  19. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Because that's not bmw or porsche,
  20. Nospinzone
    Jul 1, 2013
    7,746
    Weston, MA
    Paul
    Unfortunately, as documented on this site, that is not possible.
  21. 2006m5
    Dec 19, 2008
    923
    Stinks
