Pulled codes from my 1995 F355... | FerrariChat
Discussion in '348/355' started by B Feelgood, Oct 6, 2007.
  1. B Feelgood
    B Feelgood Rookie
    Oct 16, 2005
    35
    Pittsburgh, PA
    Brian
    I had a CEL 1/4 come on yesterday so I pulled the codes in the evening. Heres what I got.
    4114 - TDC Control unit recognition
    1211 - Lambda regulation
    1212 - Additive value for self-adaptation Lambda regulation
    The car has 10,000 miles and I just got it on October 1st. I opened up the air boxes and it has K&N filters. On one of the filters, the black rubber trim was hanging loose and the back half of the filter was caving into the box. The other side fit fine. I should also note, I pulled the codes with the engine running. However, the first time I tried I just turned the car over and didn't wait a few seconds for the lights on the dash to go out.
    Looking for some advice before I have to take the car somewhere to be fixed already :(
  2. B Feelgood
    B Feelgood Rookie
    Oct 16, 2005
    35
    Pittsburgh, PA
    Brian
    Could the air filter being caved in possibly cause those two codes to be thrown?
    Its hard to imagine that an O2 sensor with only 10k miles would be bad already.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Naw, the air filter wouldn't cause the O2 problems, but it could cause problems with the MAFS.
    As per our discussion, I would swap the O2 sensors from side to side, clear the codes and then see what pops up. Oh yeah, while your under the hood get some new air filters in there.
  4. B Feelgood
    B Feelgood Rookie
    Oct 16, 2005
    35
    Pittsburgh, PA
    Brian
    Thanks for the enlightening chat before! Im down in the garage now on the laptop. You did mean to swap the O2 sensors behind the oil filter and not the ones on the cats correct? Also, where is the battery and best way to get at it so I can pull the negative terminal?
  5. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    It could be a bab cat. That was what happened to my 95 F355.
  6. B Feelgood
    B Feelgood Rookie
    Oct 16, 2005
    35
    Pittsburgh, PA
    Brian
    nevermind those were the coolant sensors...
  7. jm348
    jm348 F1 Rookie
    Mar 21, 2007
    3,017
    Redondo Beach, CA
    Jeff M
    Is a bab cat similiar to a bob cat?
  8. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    No.
    I meant for you to check the connection for the O2 sensors, located by the oil filter. Then when you swap them, you swap them from one cat to the other.
    The battery is actually in the front fender well. But there is a connection in the engine bay, on the right hand side looking in. You should see it near the shock tower.
  9. k wright
    k wright F1 Rookie
    Feb 4, 2004
    2,544
    North East TN
    Kent Wright
    Thanks for posting a full size photo of you thumbnail.
  10. f355spider
    f355spider F1 World Champ
    18,044
    K&N will warranty the bad air filter. I would just get new stock ones.
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    A bad phase sensor (code 4114) will cause the 1211 and 1212 codes. I'm not saying that's 100% your problem, but that code will trigger the other.
    However, that particular code is usually ignored because it is seen everytime you check the codes with the engine off. But since you checked the codes while the motor was running, it's real and it can be an explanation for the other error codes.
    I don't know about the 355, but that's an inexpensive part and an easy 4 bolt swap to fix the problem on a 348.
  12. B Feelgood
    B Feelgood Rookie
    Oct 16, 2005
    35
    Pittsburgh, PA
    Brian
    I got the o2 sensors swapped from left to right this evening. I also cleaned the connections for them and the coolant sensors. However, I managed to mess up one of them and need a new one before I can start the car again. Does anybody know if the two coolant sensors located behind/underneath the oil filter are cross referenced with a universal part that I can buy at my local auto parts store? I would hate to have to order one online and not be able to drive the car until late next week. I believe this is the one I need http://www.ricambiamerica.com/product_info.php?products_id=201043.
  13. B Feelgood
    B Feelgood Rookie
    Oct 16, 2005
    35
    Pittsburgh, PA
    Brian
    In another thread I seen someone did indeed say the temp sensor was made by Bosch which means a local parts store may have one. But there wasn't a part number in the thread :(
  14. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    If you get the sensor from Dan (Ricambi) he will have it out to you pretty quick. Dan is the man when it comes to this stuff, great service, Dave isn't bad either. :p
    Either that or you can try and source the sensor yourself. It will just take some detective work on your part.
    By the way, how did you goof up the coolant sensor?
