Pulling a 3x8 Engine | FerrariChat
Discussion in 'Technical Q&A' started by Verell, Aug 26, 2004.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    JWise, I, & another of the local FChat members will be pulling John's engine this weekend. We've researched the archives pretty thoroughly as well as the engine removal procedure in the 308 FAQ.
    Have one question for FerrariFixer, Rifleman, & any other members with relevant experience:
    Which way do you tilt the engine when pulling/installing it?
    All of the FChat descriptions have the engine being tilted almost 90 degrees towards the rear of the car. This is usually done by lifting by the forward intake manifold bolts, or by a strap around the front head.
    However, We also asked the other Ferrari board & JRV recommended tilting it TOWARDS THE REAR! He saw a film of the factory tilting the engines that way when dropping them into nnew 308s. He believes that it makes it much easier to avoid bumping the rear window or engine compartment rim. Also posted photos that look pretty reasonable.
    See:
    http://www.ferrari [-] talk.com/discus/messages/5/6286.html?1093367497
    Umm, you'll have to edit the link a bit, seems that there's automatic censoring in place.
  2. Matt Morgan, "Kermit"
    Matt Morgan, "Kermit" Formula Junior
    Nov 12, 2003
    405
    Ferndale, WA
    Whatworks best for me is to tip the engine reaward, until the drop down gear case is veritcal, or straight up and down. One man can pull them if they are tipped that way, as the clearance is the best.
    I have seen them rigged many ways, and they work. But we fabricated rigging for the purpose. 4 pieces of angle, drilled to match the end intake ports, with 1/2" turnbuckles going from each one to a common bridle ring. This allows us to tip, tilt in any direction by simply turning the turnbuckles in or out.
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    I tie a strap around the 5-8 head and lift it from a point between cyl 6-7 near the carbs/injectors.
    Throw a bit of old carpet on the roof and tuck it into the rain channel near the window and it'll be a breeze.
    Target angle is to have the 1-4 can cover pretty much vertical.
    As you tilt the engine, support the rear edge on a jack to stop it swinging when it's clear of the rails, then just raise it all the way on the crane.
    Can do it on your own unassisted in about 5 hours from running car, less with help. Word of warning...if you drain the coolant from a hose and NOT the block drains, you'll get a squirt out the heater outlet so make sure the boot cover is closed or a plug on the outlet pipe!
    If you can drain the block drains you'll save the hassle, but they're often seized/rounded out.
  4. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Are you guys referring to Birdmans car?
    If so, why are you pulling the engine?
    Thanks,
    Jim
  5. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    #5 jwise, Aug 27, 2004
    Yep, Verell and I (and various other usual suspects) have a busy few weekends ahead. I can't wait to really get into it and start installing parts instead of removing them!
    Thanks everyone for all the tips- very useful and time-saving. Hopefully by the end of the day Saturday we will have it out.
    A few questions:
    1. We already pulled the rear header (it's a euro car, if that helps), but should we also pull the front header?
    2. Do the engine mounts stay on the engine or attached to the frame?
    3. I was thinking to go ahead and pull the bell-housing- is this necessary before pulling the motor? We are going to split the trans-axle from the block later anyway, so it has to come off sometime.
    4. Half-shafts are already disconnected from the differential- do they also need to be removed from the hubs to make more room?
    Here's how we left it last weekend- muffler, heat shields, rear header, p-brake removed, and half-shafts disconnected and covered with zip-loc bags.
  6. jwise
    Apr 2, 2003
    781
    Portland Maine
    Nope- not Birdman's car. It's my 308, although he threatened to come help us!!!
    Just kidding Birdman- hopefull we'll see you.
  7. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    One thing I did to insure not breaking the rear window is to put a 1/2 inch piece of plywood over the window and slide it into the rain channel and let it go above the window by an inch or so.
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Thanks, for this & the other tips. This is EXACTLY the sort of things we're looking for. They'll help us save time. If we can't get the block drains out, maybe a shop vacuum on the heater line can suck most of the water out of the block before we start the pull.
  10. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Verell,
    Where was the location of this barbeque? Is one going to be held next year? I'd love to drive up there for it.
    Jim
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    I pulled the engine out with about a 45 degree angle tilt toward the rear of the car. To protect the rear glass, I built a 1/2 plywood "3 sided box" and put it in the rain gutter. I also use 3 very thick towels over the top edge of the car. I got the idea from a picture Peter posted.
    Coming in was the same thing.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    BBQ was in Groton,MA (Just S & a bit W of Nashua,NH).
    One next year is likely based on feedback we got & great turnout.
    Tnx Yelcab, We've got the thread with Peter's picture. Think we've located all the motor pull threads in the archives, spent about 4 hours searching & I had a pretty good idea where they were since I'd read them when they were originally posted.
  13. tbakowsky
    Sep 18, 2002
    20,038
    The Cold North
    Tom
    You can leave the axels attched to the wheel hub..but removal will make the pull much easier. The front exhaust manifold must be undone. Undo it and pull it away from the head as far as you can. During the removal of the engine you will have to wiggel it around a bit inorder clear the lower portion of the trans. When installing the engine drop it in the hole before hand and try to lean it against the fire wall by balancing it on the fuel cross over pipe. As you lower the engine move the manifold around as needed for best clearance. The engine will not beable to tilt enough with the mainfold installed. In order to gain access to the left side of the manifold nuts removal of the starter makes things much easier to access.
  14. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hey Gang,
    Though I won't make it this weekend to help, I'll make it up before you're done to lend a hand. The timing (no pun intended) is bad...I'm in the throws of trying to frame my new garage before winter!
    Jim, check out the New England section, we are constantly having FChat cookouts and BBQ's here in N.E. because we New Englander Ferrari owners know how to have a good time! Steve Rochlin usually has a cookout in October. Join us!
    Birdman
  15. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    I will Birdman, from the looks of it you guys seem to have a good showing up there.
    I'll try to join you guys in October.
    Thanks,
    Jim
  16. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
  17. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Thanks for the advice!
    This is just a preview, we hope to write up a step by step procedure based on our experiences & post it later. Also have some pictures, but we were so busy working that pictures are going to be a bit sparse. Maybe we'll get more during re-assembly.
    Took all day getting ready for the pull, but about 5:30 it was out!
    Thank goodness Spider348. came over about lunch time. We really needed him several times, including the actual engine pull. Two people probably could have done the job, but they'd be exhausted & nervous wrecks from jumping between the hoist & the engine.
    ROTATED ENGINE FORWARD
    Actual lifting went quite well. Took JRV's advice & tilted the motor FORWARD, contrary to common practice. It was snug, but it came out w/o tearing up the lip below the window, or cracking the window. In fact, was very easy to keep it away from the lip & window, but at times had only about 1" clearance. Maybe rotating the engine another 10-15 degrees would have given another 1" clearance. Will find out when we install.
    We hadn't quite harnessed it right. Doubled a heavy nylon strap around the 1-4 bank head with the lift point over the intakes.
    Should have reversed the strap with the lift point coming up over the exhaust manifold.
    Result was that the balance point was too far forward. To get the necessary forward tilt we ended up using an additional ratcheted nylon strap
    to lift the differential. The ratchet was barely up to the job.
    Somehow when we looked at my printed out copies of JRV's Pix we just couldn't't see how the chains were attached. It's obvious now, the lifting point is just about straignt up over the exhaust side of the 1-4 bank.
    I also couldn't figure out how JRV was attaching the chains. Again, tonight it's obvious. There's one hook on the reaction bar mounting bolt, & the other goes down to the differential. Think the big difference is that the printouts were B&W, & the chains don't show up very well at all. However, they were a big help!
    Once we got the engine rotated into the proper position (Bank 1-4 cylenders were vertical) the engine came out essentially straight up. Was very nicely balanced & didn't want to twist or do anything else untoward!
    FORWARD MANIFOLD STAYED ON ENGINE.
    Also, contrary to common practice, we did NOT remove the fwd manifold! The forward tilt let us leave the fwd intake manifold on the engine during the pull. The manifold nicely rotated out of the way directly under the engine!
    HALF-SHAFTS STAYED IN
    Completely removed the rear motor mounts from both engine & frame. Once they were out of the way, the half-shafts nicely laid across the frame rails. We left them attached to the wheels. Were even able to push the car around with them nestling on the rails! Just covered them with a pair of heavy ziploc bags to keep dust out.
    It's out & safely perched across a set of 2x4s stretched across the engine hoist's legs.
    Tomorrow we'll mount it on the engine stand. May have to fabricate some brackets to mount it to the stand, but can't tell till we get the flywheel
    off. Existing stand mounts on the bell housing studs may do the job once the spacer behind the flywheel is off.
    I've pulled a lot of engines, but the only one that was this snug was my '58 XK150 Jag's engine.
    Had to get the lifting angle just right to snake the engine over the radiator while the tranny was coming out of the bell housing. The Jag pull was somewhat more challenging because we had to keep moving the hoist backwards while raising the engine. ie: had to lift the engine/tranny along a centerline that angled upwards at about 30 degrees. Any upwards motion had to have about 2x that much forward motion.
  18. yelcab
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    Good job tilting it forward, I have to try that next time.
    Be careful with using the long studs to mount the engine, mine ... bent slightly. The 308 was the hardest engine I had to install, coming out was easier. Dropping it back in was a real bear.
  19. Gianluca
    May 6, 2003
    349
    Gianluca Chegai
    "FORWARD MANIFOLD STAYED ON ENGINE.
    Also, contrary to common practice, we did NOT remove the fwd manifold! The forward tilt let us leave the fwd intake manifold on the engine during the pull. The manifold nicely rotated out of the way directly under the engine!"
    I tried to remove the engine (lifting from the front) without taking the front manifold out and it was a total fiasco. Very nice to know this other tecnique you used. I will try it nex time.
  20. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Looked that way to us also, that's why we didn't drop it back into place & redo the straps after we realized we'd gotten the lift point wrong.
    I've got a couple of ideas for dropping it back in. Hopefully one of them will work. I suspect that the toughest part of re-installation is coaxing the engine into rotating back towards it's normal orientation & position while keeping it clear of everything.
    Wish I could put the car on my lift, position the engine over the bay, then raise the car until the engine was in the bay. Would then have access to things from underneath which would make final rotation & positioning a lot easier. Unfortunately, I just don't have space for the engine hoist while a car is on the lift.
    TODAY'S PROGRESS:
    - ON ENGINE STAND
    Anyway, got it mounted on the engine stand today, had to pull the flywheel & rear spacer to get long enough studs to go thru the engine stand's stand-off brackets. Next time I think I'm going to make some stud extenders that thread onto the existing studs, the extenders would havehave short studs that just go thru the engine stand's stand-off's. Alternatively, I may make extra long metric threaded stand-offs for the 308 engine.
    Other than having to pull the clutch, flywheel, & spacer there weren't any big issues with getting it onto the stand.
    Turned out that it was a good thing we pulled the engine. We discovered that the crankshaft oil seal had begun seeping oil onto the back of the flywheel which was then slinging it all around the bell housing. The seal was fine a year ago when the clutch was replaced, so the seal was left alone. Anyway, the new clutch hadn't been oil contaminated yet, so we got to it in time. Otherwise wouldn't have discovered it until the clutch started slipping & may have damaged the flywheel.
    We spent most of the afternoon removing 21 years worth of grime from the engine. According to records the engine has never been pulled, & we didn't see anything that indicated otherwise.
    Am having to do a bit of machining in order to use my radial arm drill press to drill out the studs. At max extension, the drill tip is about 30mm away from touching the studs.
    This is after we dismounted the drill press radial arm from the floor stand and reinstalledit on the bench stand which we'd on the floor stand's work table. This gives us lots of head height adjustment, but it just can't quite go low
    enough.
    Am removing the bench stand's central column & am making T-nuts to mount it directly to the bench stand's work table. It looks like this will drop the head the necessary distance.
    If not, then the next step is to cut down the bench stand's colum. The column is longer than my mini-lathe's work bed. However, I may be able to use a steady rest to support the free end & let it overhang the end of the lathe bed. Alternatively, There's a friendly local machine shop that can easily handle the job.
  21. jwise
    Apr 2, 2003
    781
    Portland Maine
    #21 jwise, Aug 30, 2004
    Here's a little more info and pix:
    The weekend went well. As Verell said, we got the heart out, mounted to the stand (by removing spacer behind bell housing) and started the cleaning process.
    Funny scene- we had the motor removed, but still dangling over the car. The three of us were standing there looking and the oily lump, and feeling a little proud of ourselves. Suddenly, I think all three of us came to the realization that if that hoist, straps, hooks, etc decided to fail right now, we would be in big big trouble- so we quickly pushed the car (she looks like some off-road sprint car without the weight of the engine) out of the garage and put the engine down on some 2x4's so we could really admire our work. It was time for a beer!
    So, more thanks to Verell, and spider348 for the help. It's coming along. Now, we can actually do some work, instead of cleaning and removing.
    Here are some pix:
  22. F512M
    F512M Formula Junior
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    Great job guys. JRV has certainly pulled enough 3X8 engines to get it right the first time. Keep posting photos of your progress. JRV at Pinnacle Motorsports is proud of you guys.
    JL
  23. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    WoW! I'm really sorry I missed it. Great job! Look at the access you now have to the engine bay! Looks like a great time to replace all those little fuel breather hoses and stuff. JohnW, I'm sorry this had to happen, but you have to admit, once this is done and put back together, you should be cool for a long long time! Are you going to replace the other timing bearings while you're at it just to be safe?
    Birdman
  24. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Great thread guys, well done. Always instructive to see how others do it and get a sense of the "if I'd have known this before, I would have..." issues.
    Interesting too to get a decent look at the height of the trans and the opportunity to lower the CoG from a longitudinal mount/inline trans (a la 348 etc).
    Some combination of this thread, others on engine pulls and Newman's restoring efforts ought to be part of a "permanent record" we can all look at when the time comes to do our own engine pull/restoration/removal of the interior etc.
    Philip
  25. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    My dream is to write the 3x8 equivalent of a Haynes manual someday. Probably will have to wait until I retire tho.
    BTW, don't you consider these threads to be 'permanant record'? Only took me a couple of hours to dig out the great engine pull & timing bearing replacement articles in the Old FerrariChat Tech Q&A archives going back to 2001 or so.
