Pulling apart my broken F430 gearbox! | FerrariChat
Discussion in '360/430' started by WillAsh, Jun 6, 2023.
  1. WillAsh
    WillAsh Rookie
    Oct 21, 2022
    28
    William Ashmore
    Anyone have any torque specs when I come to put this back together?
    JSP, rizzo308, Mario Andretti and 5 others like this.
  2. LorenzoR
    LorenzoR F1 Rookie Rossa Subscribed
    Sep 26, 2015
    3,182
    Sarasota Fl/Pittsburgh
    Will Great video
    Very interesting and Thanks for posting it. I'm hoping you video dismantling and assembly
    WillAsh and AandSC like this.
  3. Flyingbrick242
    Flyingbrick242 Formula Junior Silver Subscribed
    Feb 26, 2017
    677
    Northern AZ.
    Interesting Video...must say I never seen a shift sleeve come apart like that.!
    I agree the internals are well proportioned [beefy] with excellent attention to serviceability.
    Pressing that assy back in with the gearbox still in the vehicle may be challenging.?? Good Luck
    Props to your ingenuity.!
    Please Keep us posted with your process.
  4. imahorse
    imahorse F1 Rookie Silver Subscribed
    Nov 25, 2017
    4,356
    WI
    Dustin
    I have a rebuild pdf for a 430 gearbox. PM me your e-mail if you would like it.
  5. collegeboy
    collegeboy Formula 3
    Aug 25, 2007
    1,371
    Texas and Kaua’i
    Mikey
    Is the challenge transaxle the same as the standard transaxle?
  6. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,307
    Ian Riddell
    Dustin, do the instructions come with the assembly tools required? I know I had trouble finding the tools I needed for my F355 gearbox.
  7. WillAsh
    WillAsh Rookie
    Oct 21, 2022
    28
    William Ashmore
    New syncro and shift fork are in.
    Just waiting on a couple of bearings.
    I’ve also purchased the Hill Engineering alignment jig. I wonder if that could be so far out to have over stressed the shift fork. It could be an answer to how this has happened. Welcome any other ideas worth checking!
    Sergio Tavares likes this.
  8. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    I never thought that was doable with the gearbox ... still in the car.
  9. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Nice video, I've seen you racing on Beyond The Pedal.
    Synchros are a weak link on these gearboxes and it's usually 3rd.
    Sergio Tavares and WillAsh like this.
  10. imahorse
    Nov 25, 2017
    4,356
    WI
    Dustin
    It tells you the tools you need. Good luck finding them. There are ways around needing a lot of them though.
    Qavion likes this.
  11. 67bmer
    67bmer F1 Rookie Silver Subscribed
    Oct 28, 2015
    2,975
    MD
    Your transmission and differential look identical to my 360's.
    I thought 430s had an E-diff and that they might be quite a bit different.
  12. imahorse
    Nov 25, 2017
    4,356
    WI
    Dustin
    They both share a lot of the same components. Not all, obviously.
  13. WillAsh
    WillAsh Rookie
    Oct 21, 2022
    28
    William Ashmore
    This is a Challenge car so a mechanical differential
  14. Rifledriver
    37,105
    The only time I ever took a 360 or 430 gearbox out of the car was one warranty replacement back in 99 or when the motor needs to come out.
    I don't know why people work so hard.
    mwstewart and WillAsh like this.
  15. Rifledriver
    37,105
    I have seen a lot of Porsche sliders break but never a slider for conventional syncros.
    Reinstalling is easy.
  16. yelcab
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    I did have to take 360 and 430 gearboxes out to do clutch jobs. I don't think the gearboxes stay in for that ...
  17. Rifledriver
    37,105
    Why not? I never pull them except when the motor is coming out.
    Why take the car apart?
    When we were doing ring gear recalls in 99 I did 2 a day and when I was done no one knew they were ever apart.
    Qavion likes this.
  18. 24000rpm
    24000rpm F1 Rookie
    Aug 31, 2012
    4,653
    China and California
    it looks like the fork is casted and then heat treated, doesn't it?
  19. Andrie
    Andrie Formula Junior
    Mar 6, 2015
    726
    Bay Area, CA
    Andrie Hartanto
    Thanks for posting this. I suspect I might have to do this sometime in the future, albeit on street car. @imahorse ill be interested in that pdf. I’ll pm you for it.
  20. WillAsh
    WillAsh Rookie
    Oct 21, 2022
    28
    William Ashmore
    Next one is up. Pretty long winded and boring really but a lot to go through to hopefully help others!
    Different GoPro, still rubbish audio
  21. WillAsh
    WillAsh Rookie
    Oct 21, 2022
    28
    William Ashmore
    For those interested, the gearbox is back together and fully working again.
    it was easy slipping the gearset back into the casing still in situ on the car.
    Video to follow!
  22. 360trev
    360trev F1 Rookie Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Well done Will, glad to hear it's alive again!
    Sent from my CPH2145 using Tapatalk
  23. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    Ring Gear recalls?
    Bad metallurgical or fasteners? I have difficult imagine why else Ring Gear fail...please share Thank you
  24. 360trev
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    They didn't put enough bolts on so they would peel like a banana [emoji529] under some circumstances which could happen in the real world.
    The upgraded version has more bolts so didn't fail after the revisions. It only impacted 1999 MY 360s AFAIK. Vast Majority have been replaced by now, if not all.
  25. Rifledriver
    37,105
    Done on Hewlands all the time. This isn't much different.
