Pulling the engine? | FerrariChat
Pulling the engine?
Discussion in '308/328' started by akimmel, Oct 29, 2009.
  1. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    I was just about to get to the point of starting my 1983 308 QV, after several months of down time and quite a few hours of refurbishing fuel and exhaust components, when I decided to change the oil. Yikes! Chocolate milkshake and some whitish paste-like substance on the bottom of the drain pan. Looks like an antifreeze leak to me.
    I am at the point where there are no fluids in the engine and exhaust/fuel components will be easily removed as they were just put on. I am tempted to pull the engine and look for this issue as well as touching other things that are on my list. I have had experience with Chevy small blocks in the past but I know this is a different level of difficulty. I have tools but I am not equipped like a repair shop.
    So am I crazy? If the consensus is yes maybe I'll get rid of the car.
    If you think that it's worth a chance I could use any amount of advice including what special tools or engine stand works best.
    I appreciate your comments.
    Looking for moral support! It would at least be fun to document and share the experience.
    Art
  2. BigTex
    79,380
    Houston, Texas
    Bubba
    They come out, for sure!
    Just take it slow and easy around the rear window, lot's of folks hanging around here to ask questions for help...
    I might let Norwoods do the rework, once it's out though, lots of little quirks on these.
    It's not a Chevy for sure!
    ( And I drive those too!)
  3. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Art, if you have basic tools, and some prior mechanical experience, and you're careful then yes, go right ahead and take out the engine and check out your issues with what looks like coolant in the oil. Yes, the 308 engine is more complex than a SBC but it's still just an engine and all the basic principles apply. I'd reco getting a WSM and searching past threads here on tips how to remove the engine efficiently, and how to do such things as remove the heads properly.
    I suggest the above because you'll have a real hard time selling the car for anything much with that issue (coolant in oil) - prospective buyers will tell you that you need a new engine and you'll get peanuts for the car.
    Again, ferrari's are still just cars with seats, wheels, engine and gearbox - there's nothing that difficult or incredibly special about them. It's not like only the Pope or Guiseppe Sarducci can work on them (despite what some nose-in-the-air f-car owners will say).
    Good luck and be patient and careful!
  4. BoxerCrazy
    BoxerCrazy Formula Junior
    Nov 7, 2002
    355
    Charleston WV
    Douglas A Hunt
    if its been sitting for a while it could be moisture condensed in the oil....
    was the antifreeze/coolant level low or non existant? maybe do an oil change and run the car for a bit then flush it out and change it again, all the while monitoring your coolant levels and then see if the oil stays "clean" or gets contaminated again.
    good luck, and hope it is something minor...
    doug
  5. Traveler
    Traveler Rookie
    Sep 30, 2009
    46
    I say dive in. Pull the engine, look for the fault, and hopefully it will be something fairly simple (inexpensive) and your car will be on the road again. The feeling of firing it up and taking it down the road after you have overcome this will be amazing! Hey, this is nothing more than a stumbling block on the path of Ferrari ownership.
  6. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    I'm with BoxerCrazy. A little bit of diagnostic work before you take it apart will either tell you there's nothing wrong or help locate the problem later. Running it for a short period with fresh oil is unlikely to cause any damage. Depending what the oil looks like, condensation is always a possibility. You could also send the oil to be analyzed and find out what is really in it before you do anything.
    Tom B
  7. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    Does anyone have a recommendation for oil analysis? If there is ethylene glycol it will not be condensation.
    Art
  8. GeorgeDodson
    GeorgeDodson Karting
    Feb 12, 2008
    193
    Oak Ridge, TN
    George Dodson
    I agree with Doug. It could be simple condensation. That happened to me with one of my Morgans. I'd let her idle up to operating temperature, watching the oil pressure, then just let her run for a half an hour. then check the oil again. Change oil and filter and repeat once. If it is condensation, the oil should clean up and stay clean. If not, there is plenty of time this winter to pull it.
  9. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Utah
    +1 good advice
    James Patterson's Norwood Performance will do you right.
    cheers
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,570
    San Carlos, CA
    Mitchell Le
    I had the same thing in my 911 when I drove it very little and just for a very short trips. And, it does not even have coolant in that car. I say, drain the oil, change the oil, and drive the snot out of it for a week to see if it comes back. Then pull the engine if it does.
  11. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    Another rookie here and I done a major this spring with excellant results. Two things I learned very quickly-------------one, a standard engine crane will not lift the engine high enough so plan on a hoist suspened fairly high. second, shop for parts!!!!!! The price spread is very high. Finally ,as others have said, Fcars are just like any other but getting over that mystique will take awhile.
    This is the place to find out what you need to know~~~ Tom
  12. tazz99
    tazz99 F1 Rookie
    4,451
    Kennesaw, GA
    Seth
    Agreed. I would drain and refill, run until normal, 180ish, on coolant and oil temp is up to at least 200 or higher. Let things stabilize for a few minutes at these temps or higher. Shut it down drain the oil, if all looks OK, refill, new filter, drive it for a couple of hours easy, check the dipstick for any signs of moisture. If all is still OK then I think you will have dodged a bullet. Keep checking the dipstick after every run for any signs of moisture.
  13. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Also, pressure test your cooling system. Do the simple things first before diving into a rebuild. (Though a rebuild can be fun...)
  14. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    I am going ahead with oil analysis - probably a good deal at $22.50. Blackstone Labs claims they can detect antifreeze with their test easily. I'll post the results that they send. I appreciate all of the good advice. At issue at the moment is that there is no antifreeze, gas, oil, gear oil, or even brake fluid in the car - so cranking it up is a bunch of work and a few bucks to find out if I need to pull the engine. We'll see what comes back from Blackstone!
    Art
  15. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    #15 akimmel, Nov 11, 2009
    Well I got the oil analysis back on my 1983 GTSi QV, confirming antifreeze and showing high fuel content. I suspected the fuel as that's why I was refurbishing the fuel system to turn the injectors from a hose back to a mist.
    So I am going ahead with the engine rebuild. I got a quote that I can manage from Norwood's here in Dallas where I disassemble and reassemble everything but the heads - they provide parts, machining, magnafluxing, and head assembly.
    I will be searching this website for helpful hints in pulling the engine. Anyone reading this that has procedural knowledge please point me in the right direction. I plan on thorough photo documentation as well as watching what goes on at Norwood's if they don't charge too much for watching.
    I will share my experience in case it helps some of you out there.
    Wish me luck.
    Oil analysis attached.
    Art
  16. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    Art, thanks for the update. I'm very interested. Your plan to do most of the work w/ Norwood's help is also my 'what if' plan.
    I've got $10K saved for a rebuild if it ever happens....is that enough?
  17. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    Would this just not indicate that the head gasket is blown?
    Aaron
  18. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    The quote that I have is just under your 10K. I'd be foolish to think that there won't be more that I want to do. The best I can do is keep you appraised of the situation. I'm not sure that I want to share my extravagant spending with everyone (wife excepted of course) so if you send me your email I can keep you apprised of actual costs. [email protected].
    Glad to have moral support.
    Art
  19. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    Probably Aaron
    But deep inside I have been aching to pull this engine apart - so just do't tell my wife that it's not absolutely necessary. Besides it keeps me at home :)
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    Art, you're going to need a few specialty tools, I didn't catch if it's 4 or 2valve. the 4 valve needs a special wrench to get the head nuts off. and all versions need the a ring nut socket. all tools available from Baum.
    Also get a 'complete' gasket set, Ferr-parts has 'em I think there about 2k or so, it'll have every gasket, washer 'o' ring you'll need plus some extra.
    Also get your hands on a WSM! you'll need it for the torque specs and the setup for the front timing gears assy.
    replace all the bearings; you're in that far it's just good sense at that point.
    I'd say your biggest expense is going to be the 'finish' of the assy. i.e. nuts & bolts, nothing like new hardware to spiffy up a rebuild. you can re-plate the old stuff or replace. replacement takes some leg work to get the right hardware that is the same. the hardest being the cam cover acorns.
    Good luck Enjoy the project and remember it's normal for you to think "well since I've gone ths far..."
  21. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Be sure to check/replace the, timing belt drive pulley, outer bearings.
  22. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    Where is the ring nut socket used? Thanks
  23. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    I just got off the phone with a guy at Peak antifreeze. I read a post yesterday from a Rolls Royce owner in England about his problems with using the new extended life anti freezes in older cars. It made his leak after a short time...(he had a fresh engine)
    It seems the new formulations use organic acid technology for corrosion inhibitor and it can be the kiss of death for older engines. The man at Peak agreed and recommended their "old"
    green formulation which uses inorganic acids in the formulation. And now I read a post about an antifreeze leak in an older engine.....
    Anybody else heard about this?
    Dave
  24. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    There are several good threads on pulling the engine. One thing to keep in mind if you are doing it in a garage, do you have enough ceiling hight, i.e. top of the boom to the bottom of the engine + height of top of engine compartment to ground level. I found with a 8 1/2' high ceiling, I can remove the engine if I lower the car to where the chassis is almost resting in the engine crane legs PLUS I level the engine. Remember, to pull the engine, it must be tilted backwards (front head higher than the rear).
    Take you time, think everything out, and you will have no problems removing the engine.
    Good wenching
  25. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    I have seen the same thing in some older Corvette ZR-1 LT5s if you all dont know the LT5 isnt some small block chevy, but anyway a few guys have had issues using the new antifreeze you can get off the shelf that they all claim is compatible on these engines it look to have ate up the head gasket causing the failure at the cylinder area
    Ill be glad to dig up old photos of these.
    To the original poster I had my 308 for about a week and had the motor pulled just to give me more room to replace all the old fuel lines and clean up everything.
    I also took that time to change out all the gaskets check the valve shims and replace the belts and bearings and give a good tune up.
    I had never even sat in a ferrari before I picked up this car my first one so don't be afraid of it plenty of help here and I asked around and did a lot of searching the forums.
    good luck!
