Pumping up brakes | FerrariChat
Pumping up brakes
Discussion in '360/430' started by Speed seeker Don, May 30, 2018.
  1. Speed seeker Don
    Feb 19, 2018
    20
    Donald Roskos
    I need to pump them to get a firm pedal. Anything special bout bleeding the brakes on a 2004 360?
  2. rizzo308
    rizzo308 F1 Rookie
    2,780
    Perth, Australia
    riggio
    Remove large panel in trunk compartment u may have to get to front bleed screw from there and then panel covering brake reservoir there's 2 bleed nipples on top of master cylinder PITA to get to start there. Then bleed from rear corner furthest from mast cylinder. If ur car is L/H/Driver u will start from pass rear then driver rear then pass front then driver front. Good luck
  3. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    You might as well change the fluid .....
    whatheheck likes this.
  4. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    A motive Power Bleeder makes flushing the fluid a one man job and very easy. First time I flushed my 360 brake fluid many years ago, I did not know the bleeder on the master cylinder was there and still had a mushy pedal. Bled the master cylinder as mentioned by rizzo308 and it firmed right up.
  5. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Yup, I use Motive and run a bleed sequence on the computer.
  6. ItalGerBrit
    Mar 15, 2016
    906
    S La
    Stupid me. What is bleed sequence on computer? Does that involve activating the ABS?
  7. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
