Purchasing a F355 with over 50k mileage | FerrariChat
Discussion in '348/355' started by CCWillF355, Nov 14, 2019.
  1. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    New member and hopefully soon to be F355 owner. Well been looking for over a year, looked at everything from super low mileage to 60k cars.
    Want a car I can drive and enjoy, so not worth getting a below 25k miles as it’ll depreciate too much.
    So was looking at cars around 40-60k, any thoughts on a car with this mileage? Anything be own a car with this mileage and have experience of ownership?
    many help would be great thanks.
  2. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,338
    Robb
    It will all be based on condition of the car. Mechanical records help. You’ll want to see what the car needs, to have no remaining issues.
    More things wear with higher miles but as long as you or the previous owners stay on top of the maintenance, no reason to not have the same experience if not better than low mileage examples.
    Robb
  3. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Owner Regional Sponsor Silver Subscribed
    Mar 30, 2013
    3,168
    DC
    Eddie
    At the very least make sure valve guides have been done. Like Robb said, mechanical records help a lot. I've looked at a few higher mileage 355s and most of them had some serious engine work so keep that in mind.
  4. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    One of the cars I’m looking at has had extensive work done to suspension, brakes etc. The value guides have already been done too. Seem like all of the things which would need replacing at the higher mileage stage have been done, including a new clutch.
    Robb and Qavion like this.
  5. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    One of the cars I’m looking at has a very good history and the value guides have been done, new clutch, brakes etc.
  6. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Maintenance and functional condition is the absolute prime concern when buying these cars. Everything else is BS.
    If these cars are maintained they are amazing. If they are not then they are miserable and very expensive to deal with.
    I think you can generally get a feel for if the owner was thorough in taking care of the car or if they did the bare minimum.
    In addition one of my personal red flags would be if the car does not have headers or an aftermarket exhaust manifold at that mileage. The stock manifolds are all a failure waiting to happen. Its only a question of when. The other would be valve guides like the guys mentioned.
    CCWillF355 likes this.
  7. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    Wade likes this.
  8. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    wow, your car looks stunning, lovely spec and great to see a lot of care going into the car. I bet that’s going no where!
    I totally agree with all around what the previous ownership was, it needs to be care for well, not just keeping it going. You want to know it’s been well maintained.
    let’s see what I think when I view it soon. Hopefully ticks the right boxes, then it will be PPI time. Compression test being key.
    will keep you all update in progress.
  9. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Get a compression and leak down that's invaluable insurance otherwise its a gamble. Yes you need both. Best of luck and remember high mileage does not mean bad in the same way low mileage does not mean good, be diligent is all.
    Sent using FerrariChat.com mobile app
  10. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Over and over, the mechanics say the cars do better if they are driven. Condition is vastly more important than mileage, and regularly circulating fluids and lubricants to all the parts is a good thing. Even AC systems do better if they are used regularly.
    Challenge, MAD828, F355Bob and 3 others like this.
  11. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,016
    NE FL
    Ken
    I went to a cars and coffee this past weekend and there happened to be another 355 there.
    Mine has 45k miles, the other 27k. I had several people comment about how amazing and much better shape my car was than the lower mile car.
    My car burns no oil, original guides, great compression numbers. It has never let me down.
    It had been well cared for, a large folder of records.
    Initially, yes I wanted a lower mileage car, but I look at it this way; The previous owner got it all sorted out for me, now I just get to enjoy it. I still keep the good care going, replacing any and all questionable items.
    If I could do it all again, i wouldn't change a thing... except to get a GTS lol
  12. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    39K miles on mine. Pretty good service history and the big stuff has been done, except valve guides. Runs great, looks great, and i am not afraid to use it.
    Beetle likes this.
  13. tres55
    tres55 F1 Rookie
    3,571
    Canada
    Condition really does trump mileage on these cars IMO. You can have a 10k mile car left to rot for a decade that will run worse than one that's been driven and serviced regularly with 3-4x the mileage.
    I bought mine with high 60k miles and sold it after about 5-6k miles just recently. I sold it with an F1 issue that was the result of a failed part from the 360 pump upgrade...but besides that the car ran like a top all the way to the red line throughout the entirety of my ownership.
    That car, however, came with a binder full of receipts that, since its birth, totaled to more than the cost of the car new. :D
    Beetle likes this.
  14. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    So imagine you are buying a Ferrari from the 60s, 70s or 80s How important is the odometer reading really??
  15. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    Why both compression a leak down? If compression looks good, why do a leak down?
  16. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    I agree if a car has been care for that stands for a huge amount when considering a high miler.
    one of the cars I’m looking at has basically been rebuilt, has been hardly used since 2011. So most things have been renewed. Brakes, clutch, etc manifolds appear in good condition too.
  17. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    What's the difference between a shed queen that never gets driven and had the odometer mucked around with compared to a well sorted pampered high mileage car. Cars that are not driven have more issues than cars that are used. There are so many threads on this. Check the car out with honest people that know these cars and what to look for. A higher mileage car will be cheaper than a low mileage car and properly sorted most of the time but then there are exceptions to both. How many miles will you do and are you looking to resell or keep that's some of the questions you should be asking yourself. Good luck
  18. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    Am is to buy something I can enjoy for many years and then pass to my kids or something like that.
    has to be a car that I can drive, make my own and enjoy.
  19. Beetle
    Apr 10, 2013
    776
    All cars have issues. Get it checked out. If it's good and well looked after and your happy with it buy it and enjoy. It's Ferrari FFS.
  20. Andy 355
    Jun 2, 2013
    434
    Do they turn into pumpkins at 50k miles? What happens to them?
    Beetle and CCWillF355 like this.
  21. Sancho22
    Sancho22 Karting
    Oct 24, 2018
    182
    Northern New Jersey
    Laszlo Szanka
    I am no expert in F cars but went through similar process recently (many advised me and also red a lot of F-Chat). Had a very nice very low mileage Aston Martin which I babied and finally sold as I barely drove it. It is in a collection now. I ended up with a 1995 Rosso Corsa, Spyder with over 44K miles. Think 3 ring binder with receipts, valve guides, clutch etc done. That said I bought the car knowing that it needs several things and plan to address those in the spring. As long as you don't get surprised and you know what you are getting yourself in you are in for a treat...
  22. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    true.
  23. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    Have driven a few what car! Just have to find one that fits my spec and condition. Hopefully soon.
  24. Sancho22
    Sancho22 Karting
    Oct 24, 2018
    182
    Northern New Jersey
    Laszlo Szanka
    all the best with your search!
  25. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,254
    Worcester, England
    Phill J
    There's a general misconception that once a Ferrari hits 50K miles, the cars will be worn out, and will need major components replacing due to wear and tear any time soon, so will be more of a gamble to buy
    Conversely, there is also a misconception that a Ferrari with ultra-low miles, will still be like new, and will be several decades away from requiring any major components repairing or replacing.
    One thing that I was encouraged to do when I bought my Ferrari 348 from a highly reputable independent Ferrari specialist here in the UK, was to drive it at least once a week, for at least 50 miles, to get the car fully warmed up. It was pointed out to me that one thing Ferrari's do not like, is to be sat stationary for weeks/months/years on end. They said that a big reason for Ferrari's reputation for unreliability, oil leaks, coolant leaks, electrical faults etc., etc., is due to them being parked up for long periods, with seals drying out, condensation getting in, and such like, and then owners jumping in them, and driving them as though they were last used yesterday.
    (For the winter months, when there is ice/snow and loads of salt on the road, the specialist said that it was best not to drive the car, due to increased corrosion risks, but I should fire the car up at least once a week, not let it just sit idling, but to rev it at @ 2K rpm to start with, slowly increasing it over 15~20 minutes to 5Krpm, replicating the engine speeds of normal, early driving, until the oil temperature got to it's normal operating temperature, in order to keep the oil and coolant circulated, and help drive out any condensation).
    They told me that they had had 308's/328's/348's/355's and 360's come in with 50K + miles on the clock, that needed far less work to be done, than similar aged cars with sub 10K miles on the clocks, simply because they had been used regularly.
    Personally speaking, I'd be happier to own a 20+ year old car with 50K + miles on the clock, that is in a well cared for condition, and has a thick folder of service history and invoices, than one that has averaged 500 miles each year of its life - Especially if there are big gaps in the service history.
    Enzo Ferrari made cars to be driven - Otherwise he wouldn't have bothered putting an engine in them! ;)
    Challenge, CCWillF355, Beetle and 2 others like this.
