Push-Starting a 360 With Dead Battery | FerrariChat
Discussion in 'Technical Q&A' started by 3omar, Nov 17, 2007.
  1. 3omar
    3omar Formula Junior
    329
    United States
    Omar
    I was out with my 2004 360 Modena (manual) this evening. I parked it for 2 hours with the parking lights on. When I went to start it, the battery was dead!
    This has never happened to me before and since it was late and I was going to be stranded, I asked a couple of friends to give me a push while I tried to throw the clutch in 2nd gear. I tried it 3 times (twice in 2nd gear and once in 3rd) but I couldn't get it to start.
    I ended up calling the dealer's hotline and they sent me a flatbed truck and took the car.
    Do you guys think I might have damaged anything with those push-start attempts? I'm thinking the 360 is just like any normal manual transmission car. Or am I wrong?
  2. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Nah mate, you wouldn't do any damage ;) When you replace your battery make sure you get your charging system checked over :)
  3. VR4
    VR4 Karting
    Apr 22, 2004
    58
    vancouver, wa
    steve
    you should be ok. the owners manual even states you can push start an F1 car in the event of a dead battery.
  4. PAP 348
    Dec 10, 2005
    100,232
    Pap
    HUH :confused:
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    In the old days, I used push start in the highest gear...ei 5th/6th.
    Worked for me on a couple different cars and bikes.
    Interesting that push starting is in the manual.
  6. VR4
    VR4 Karting
    Apr 22, 2004
    58
    vancouver, wa
    steve
    the owners manual for a 360 with the F1 transmission says you can push start it if the battery is dead.
  7. fatbillybob
    Aug 10, 2002
    29,272
    socal
    How do you do that? What is the proceedure?
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The battery can't be really "dead" or you won't have fuel injection or spark.
  9. PAP 348
    Dec 10, 2005
    100,232
    Pap
    That's what I was thinking
  10. VR4
    VR4 Karting
    Apr 22, 2004
    58
    vancouver, wa
    steve
    ill have to read it again. it was worded very confusing.
    ill post it up here word for word later today.
  11. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Thanks Steve :)
  12. VR4
    VR4 Karting
    Apr 22, 2004
    58
    vancouver, wa
    steve
    PUSH DEPARTURE
    In the event of malfunctioning of the starting system, a "push departure" is possible, procedure as follows:
    -Perform the "System Start-Up" phase;
    -request "UP" when vehicle is gaining speed with the gearshift in "N".
    In any case, avoid this procedure except in event of emergency!!!
  13. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Thanks for the great info Steve ;)
    It just seems weird that you could actually push start a auto trans thats all, but I reckon that this would only work with a charged battery after you primed the F1 system, I would imagine a dead/discharged battery you would be unable to push start a F1.
    Maybe someone here has actually done this and could chime in?
  14. VR4
    VR4 Karting
    Apr 22, 2004
    58
    vancouver, wa
    steve
    yeah. the system would have to be primed.
    the reason push starting a standard automatic doesnt work is the torque converter. cant lock the trans to the engine.
  15. PAP 348
    Dec 10, 2005
    100,232
    Pap
    I thought so, Spot on Steve ;)
    Thats why me and Billy Bob were like HUH :D:D
  16. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I am thinking that you are correct if you have no alarm.
  17. fatbillybob
    Aug 10, 2002
    29,272
    socal
    I was not thinking torque converter. F1's don't have this but I did not know the car would shift to anything except park or neutral if the engine was off. I did not know you could hit the stater and shift a rolling F1 to 2nd gear anf gas it to get it to start. It is good to know you can. I wonder what the car's alarm system thinks when the engine is off though. Perhaps there is feedback to the alarm system that prevented the poster with the 360 manual to start in 2nd gear. You can have a basically dead car with decent alternator and bump start a manual trans in 99% of trys.
  18. 3omar
    329
    United States
    Omar
    Thanks guys.
