Putting in my electromotive FINALLY! | Page 5 | FerrariChat
Discussion in '308/328' started by Birdman, May 10, 2006.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,793
    The twilight zone
    I've got sneaking that Kermit is indisposed these days......
  2. BigTex
    79,406
    Houston, Texas
    Bubba
    Last seen with a pistol tucked in his belt and eyeballs counter-rotating like props on an offshore speedboat!
    I've heard........
  3. BigTex
    79,406
    Houston, Texas
    Bubba
    I've got some stainless out in the shop.......
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,793
    The twilight zone
    My Haltech E6k worked fine in the trunk. The E11 mounted in the same spot would be fine until I stopped for gas or ran into the store....then it over-heated sitting there with the exhaust heat rising and would forget how to do ignition timing and drop cylinders until I got on the road again. Not good. The new motec says mount in the passenger compartment. I guess the truck of a front engine car would be fine, but a 308 trunck gets hot. I'd say avoid the trunk.
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    +1
  6. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Fchatter David C. with e-mail address bertocchi AT charter DOT net fabricated mine up. Maybe he can fab up more?
  7. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Excellent post. Heat CAN be a problem if you have cat pipes are other situations that make your trunk very hot. Fortunately the heat is not an issue in the Euro 308.
  8. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Durable 1 is no longer around - I think any good fab shop could make a nice bracket.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,793
    The twilight zone
    I don't have cats and heat is a problem in my trunck..but I don't have insullation either and some stuff is fine like the factory ingition and my first ECU. The chip in the second ECU has problem above 85C..so I'm guessing that is about how hot it gets in there.
  10. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I just ordered an XDI-2 setup from Nick (www.nicksforzaferrari.com) for my 308QV... in part as a "prequel" to eventually putting a supercharger on it, and in part to allow me (or rather, my mechanic) to tweak more. For me and how I use the car, it should be a nice modernization/upgrade without doing the entire EFI thing which is a lot more money and work. Nick also said that if supercharging is NOT in your future, the "standard" XDI setup is quite adequate without paying the extra $300 for the more programmable "-2" version.
    There's an Electromotive dealer that's semi-local to me, but Nick provides it as a kit with everything you need specifically for the 308, plus he's GREAT to deal with.
    By the way, what do people normally do with the stock distributors? Just leave them on there?
  11. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Good info Mike, thanks..
    I'd also like to know what to do with the distributors....
    Still haven't installed mine...
    Greg
  12. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Hello Wade: Did you ever do this? I'm getting ready to install the XDI setup on my '84 QV and would like to actually cap off the distributors also.
  13. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    #113 308nut, Nov 28, 2006
  14. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    THe reason I have not posted pics so far is that I am also building a ITB system for the car. I do not have it completed yet so that is my reasoning. I will however take some better pics this week and post.
    Wade
  15. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Wade,
    I'd be up for a set of cam end caps, if they'd fit my '78 GTS. I'm planning on doing the XDI install later in the winter, or in the spring, and was having the same thoughts as Mike about what to do with the distributor caps. I'm sure there are others here who would be interested, enough to make a run of caps worthwhile for all of us. Let us know what you decide to do, cost, etc.
    Regards,
    Steve
  16. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I probably do want end-caps to replace the distributors, and I think that what you've done may be a really nice way to mount the coils as far as wiring position. Please do let us know about prices for just end-caps and for caps & mounting blocks, and post some clearer pics and/or pics from a little farther away when you can. I have a feeling that you may have come up with *THE* new clean way to mount this stuff!
  17. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I've seen pictures of it done on an injected 308 (like here) but it seems like it would be part of a full EFI setup (more Tec3 than XDI) and be tough to keep it all properly tuned... well, maybe it's more of a one-time setup and then leave it alone? I'm sure it's quite a project!
  18. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    I'll be needing a coil-mount plate and end-caps too....
    Count me in if there's a group buy..
    Greg
  19. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I could be wrong but it is my understanding that the carb cars and the injected cars have entirely different cam ends and distributor mounts. I do not believe that the simple flat plates like I made to cover the hole left by a removed dizzy will work on an injected car.
    The coil mount plate that Dave made for Steven came out really nice. I like it better than the one I got from Kermit. I would suggest contacting him as Steven suggests.
    Birdman
  20. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I've just emailed him. I'll report back here when I get a reply.
  21. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    I will have the pictures of the whole process later today, also the ITB setup you posted is exactly what I am building, we are going to CNC the intake and fuel rails to make the fitment very nice. We are also going to fabricate a plenum out of carbon fiber because I want filtered air into the engine. I will be using the TEC 3 system for management.
    The end caps are different for carbed verses injected but I have the measurements for both and can make both.
    The block use the same mounting wholes on both.
    thanks
    Wade
  22. Dr Tommy Cosgrove
    36,585
    Birmingham, AL
    Tommy
    Put me on the list for a set of caps too for my 84 308. Just let me know what I need to do.
  23. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    #123 Mike C, Nov 29, 2006
    I heard back from Dave C -- he'll take another look at what he did as a one-off for Steven R's coilpacks, and get back to me with prices for 1, 3 and 5 units in case some others here want them. I do want to cap off the distributors, but I *think* I want to mount the coil packs in the original coil location... I like the way my "red wires" wrap artistically on the QV valve covers, which is different than the carb and 2-valve cars, and that will allow for a more similar/stock-ish look. I want to wait for better photos of Wade's nice setup, but there's also the preference of having the coils somewhat away from the engine heat.
    This is the mount on Steven's car we're talking about -- I'd just probably paint mine black, or coat it in texture black like the area around it.
  24. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I would be very concerned with mounting the coils directly on the engine, therby creating at a heat sink directly into the coil pack. You may want to contact Electromotive in VA. and talk to their tech department regarding this.
  25. blainewest
    blainewest Formula Junior
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    #125 blainewest, Nov 30, 2006
    I agree with Pad, I would not attach the coils to the block without talking to electromotive first. I simply fabricated an aluminum bracket which mounted exactly where the old coils were mount using the original mounting studs.
    Attached is a picture of the caps I had made for the distributor holes. Mine is a 2v carbed car. I could have some more made up...any design could be imposed on the cap.
