Q about 328 calipers | FerrariChat
Discussion in '308/328' started by GrigioGuy, Mar 27, 2016.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,452
    E ' ' '/ F
    Enzo Gorlomi
    I'm pulling the front calipers for a rebuild. My original plan was to use vise grips to close off the rubber lines before pulling the brake line from the caliper. I've done this in the past on other cars, then hung the lines up, and never really had a problem with brake fluid leaking.
    The rubber lines on the 328 are very hard. I am concerned that if I use the vise grips, I will damage the lines.
    For those who have pulled their calipers, what technique did you use? Alternatively, does anyone know the thread and pitch of the line, so that I can go get a cap for it? I suppose I could go the "baggie and rubber band" technique, but that's a mess.
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Get a short piece of rubber/flexible hose that fits neatly, slip that over the end of it & then stuff the other end of that with a piece of wood/plastic/metal that will seal it (or crimp that with some grips or a clamp) ?
  3. ZOOOOMZ
    ZOOOOMZ Karting
    Aug 14, 2013
    248
    Austin, Texas, USA
    Tim Cronin
    I usually stick an unpainted golf tee in the flare on the end of the hose. if that's too large to fit, vinyl caps available at any store that sells wire rack shelving like Elfa, will work. (Home Depot or The Container Store is where I've bought these). Finally, at any Auto parts store, pick up some vacuum port caps (usually various sizes in rubber) and cap off the flare end at the fitting.
    Of course, if your brake hose is that hard, I guess you're replacing it, anyway, right?
  4. detroiter
    detroiter Karting
    Apr 30, 2013
    205
    Munich, Bayern
    Carter
    I used the opportunity to also flush the old brake fluid out of the system anyway. Depending on how long you yours has been in there maybe you'd want to do that as well.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Replace the hoses! If the calipers need rebuilding the hoses should be new. Once you have the new lines you can take one down to the parts store to "shop" for fittings.
    I collect all the little plastic plugs and caps that parts come with when new. I usually can find one in the assortment to block off a brake line while I'm working on things.
