QA-1 shock O Ring | FerrariChat
QA-1 shock O Ring
Discussion in 'Technical Q&A' started by Impactco, Jul 26, 2007.
  1. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    #1 Impactco, Jul 26, 2007
    What is the function of this O ring on the QA-1? Since it slides freely on the shaft, should it be at the bottom or top of the shaft at installation? Thanks.
  2. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Good question Michael. I never found out what it's purpose was for. It doesn't really do anything. I did use it to mark what the full travel of the shock was though.
  3. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    It performs well as a travel pointer as mentioned, but, it mainly serves to help prevent damage to internal valves if the shock is fully compressed.
  4. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    It is a travel indicator, much too small to dampen the forces of bottoming the shock rod into the body of the shock. BASF makes a wonderful material for jounce bumpers.
    Best,
    Rob
  5. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Yeah I was thinking that too Rob, that o'ring section is far to small for that ;)
  6. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Soory Rob, I should have been more specific, I did not mean to infer it as a bump rubber, merely that when off the vehicle many manufacturers limit compressed length to prevent possible damge.
  7. PAP 348
    Dec 10, 2005
    100,224
    Pap
    That's fair enough Brian ;)
    I have never seen an o'ring but only steel rod to limit the shock not only for that reason you state but also to compress the shock to package it smaller also to freight :)
  8. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    Got it. Thanks for the clarification.
