QA-1 Thrust Bearings/Washers?? | FerrariChat
Discussion in 'Technical Q&A' started by Impactco, Jul 13, 2007.
  1. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    #1 Impactco, Jul 13, 2007
  2. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    There is one set of washers included with the QA-1's.
    I can only guess to what these thrust bearings and washers are for, but my guess is that these are meant to make it easier for you to turn up the adjustment rings on the shocks.
    I've just finished mine (on 308GT4), and I have adjusted the lengths of the shocks while they were on the car. I've got 300 lbs springs, which are not the softest either. Okay, adjusting takes some force (reduced considerably by spraying some WD-40 or similar on the face of the washer and spring), but I'd say the bearings and extra washer are not needed. I'd spend that money on some extra fuel to enjoy the very much improved ride....
    FWIW
    Hans
  3. Geoman54
    Geoman54 Karting
    Jun 12, 2007
    50
    Northern California
    Michael McLaughlin
    Indeed --- the needle bearing plates are to greatly reduce the effort required to turn the ride height adjusters. However-- these are of more value for a track car where you may be changing ride height to suit track conditions and/or fine-tuning handling characteristics. For a street car, once you set the ride height you rarely mess with the adjusters again.
    IMO --- of course.
    regards,
    Mike M.
  4. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    Thanks for the clarification guys. I get it now. Since I don't plan on tracking the car, not necessary for my installation.
  5. Jdubbya
    Jdubbya The $10 Trillion Man
    43,489
    PNW
    Be sure to put some good quality anti-sieze on the threads per the manufacturers directions. Makes it easier to turn too.
  6. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    The bearings actually will reduce the friction in the suspension. As the "coil" spring (not a coil, actually a helix) compresses/ extends there is movement relative to the upper and lower spring mounts. The helical springs twist as they compress and extend.
    OE road car springs are mounted with elastic bushings to reduce noise, vibration and harshness (NVH). With race car, we don't care about certain kinds of NVH so reducing friction is more important.
    Best,
    Rob
  7. spang308
    spang308 Formula Junior
    Jul 17, 2004
    893
    York, PA
    What he^^ said. I put them on mine, just because my race cars always had them. Probably not needed for a street car, but...
    Spang
