QA1 - excellent source for these parts | FerrariChat
Discussion in '308/328' started by Spitfire, Jan 11, 2008.
  1. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Guys, this might be a moot point by now given that many of you have already purchased your QA1s, but I had an excellent experience with these guys when I bought mine:
    http://www.autofabracecars.com/
    The total price (without shipping) was $711.96. I think this was a pretty good price for the following parts:
    REAR
    QA1 DR5855P shock = $144.99 each
    QA1 12-250 spring = $66 per pair
    FRONT
    QA1 DR4855P = $144.99 each
    QA1 10-300 spring = $66 per pair
    Everything was in stock and shipped the same day I ordered them. Also, Josh was extremely responsive in every respect. He can be reached at (410) 796 - 8777 or by email at [email protected].
    I was so impressed that I offered to post about my experience on ferrarichat ... so, job done!
  2. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    So these are the same as Nick's Forza??? The coilovers??
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    No, Nick sells rebranded Alden Eagle coil-overs. His still require you to grind a small arc out of your A-arms.
    If you search for 'QA1' and 'QA-1' you'll find a lot of good info about these coil-overs & installation options.
    Some of the more relevant threads are:
    Group Buy: QA1 Coil-over Shock Bushings:
    http://ferrarichat.com/forum/showthread.php?p=137227182
    Installing QA-1s
    http://www.ferrarichat.com/forum/showthread.php?t=100632
    GROUP BUY: Extended Length Shock Eye Paper Weights
    http://www.ferrarichat.com/forum/showthread.php?t=142079
    QA1 Front shocks with NO A-arm modification!
    http://www.ferrarichat.com/forum/showthread.php?t=134442
    Suspension Upgrades:
    308 Suspension Springs/Shocks
    http://www.ferrarichat.com/forum/showthread.php?t=11974
    Suspension and Brake Upgrade Time
    http://www.ferrarichat.com/forum/showthread.php?t=39712
    suspension recommendations
    http://www.ferrarichat.com/forum/showthread.php?t=2388
    Aftermarket Spring Rates for a 308
    http://www.ferrarichat.com/discus/messages/256120/261228.html
  4. pdmracing
    pdmracing Formula Junior
    Feb 14, 2007
    755
    atlanta
    Qa is very popular in the drag race world too try Jegs & Summitracing for them too free shipping 2nd day on everything.
    I have found that drag racers & circle track guys are a thrifty bunch, I guess because they race weekly & have such large numbers, that the prices in these site 7 catologs are very reasonable compared to traditional road racing sources.
    things that are not lsited can be sourced with a phone call & most of this stuff is drop shipped so you get it now.
    If you are looking for tie downs & other generic track & racing stuff you will find it at huge discounts. Also they have no hassel return policies. give it atry.
  5. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    So these don't need the paperweights?
  6. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I can't answer that with 100% certainty. I have the paperweights so I'm okay! Perhaps Verell and/or Birdman might care to comment?
  7. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Yes, they need the paperweights. The paperweights were designed for the QA1. I can't comment on the Forza ones.
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The Forza (Aldan Eagle) coil-overs require modifying your A-arms to get clearance.
    I've had a couple of requests to develop something for the Forza shocks that would avoid the A-arm mod. I've taken a look at it, but haven't come up with anything I'd be comfortable making & selling. The problem is that the top of the Forza shock is hollow as it contains one of the adjusting valves. Cutting part of the top away for A-arm clearance creates a safety concern as it would weaken the internal bore's wall thickness, hence reducing the max pressure internal pressure the top can withstand.
  9. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Not that I need them myself, but I'm curious to know if you've made any more paperweights for those who still want to go the QA1 route?
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I've still got 1 or 2 pairs of paper weights from the 1st production run.
  11. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Got mine from there too. Same experience.
    Shipping to Europe was $175, by the way (for those who it may concern)
    Hans
    (Thanks again Chris, for the pointer)
