QPV04 Solenoid | FerrariChat
QPV04 Solenoid
Discussion in '360/430' started by Nickferrarif430, May 18, 2025.
  1. Nickferrarif430
    May 15, 2023
    7
    Montreal
    Nick
    Hey Guy, I need to replace the EVF solenoid on the F1 power unit. The part number on it is 195726 and model QPV04. It looks like doesn’t exist anymore and can’t be replaced by QPV02. Did someone replaced QPV04?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,786
    Central NJ
    Dominick
    Use 248091 from a good source
  3. Nickferrarif430
    May 15, 2023
    7
    Montreal
    Nick
    Thank you @flash32 i have small leak with EVF OFF at 24cc and ON at 57cc when key is on without engine running. Do you think it’s the first place to start before thinking about rebuilding the actuator?
    grtoz likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,786
    Central NJ
    Dominick
    Those numbers don't look bad
    If you want I be more than happy to give you a complementary F1 check up on the phone
    Send me a PM with contact info and good times to call
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,786
    Central NJ
    Dominick
    Just a quick update
    I got together with Nick and did a fully F1 diagnosis
    The one thing that needs changing is the e-diff solenoid ..not the clutch solenoid
    He ordered that and a new relay ( just because of extra use due it experienced due to failing ediff solenoid )
    I will leave it to Nick to close when the repair is done and all works
    Jaymac and Qavion like this.
