Question about 308 front frame design.... | FerrariChat
Discussion in 'Technical Q&A' started by greg328, Feb 3, 2006.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Question
    Do all the 308s, from 1976 all the way through the QV years (-1985) share the same front box sub-frame design?
    I'm talking about the section at the nose which houses the radiator--A/C condensor--bumper mounts..etc.. This section is about 2 feet deep-3 feet tall.
    Do all the radiators across all 308 model years mount vertically? I would assume so, since the same radiator is interchangeable throughout all 308/328s...
    I ask because my 1977 308 has a crunched lower front end. I was forced off the road at about 30 mph and ran over a concrete curb! The brunt of the impact was at the lower left radiator corner. The radiator was folded back, and all that front box-frame section is twisted beyond repair. The lower left a-arm front mount fork got slammed too, but there's only a slight bend to the a-arm. The valance was shattered, obviously. Steering rack seems OK, but the steering wheel is out of whack. Visual inspection of the left upright looks OK. Tie rods look straight...
    Miraculously, the bumper and front clip seem OK.. There's some slight buckling at the leading edge, and the bonnet has a crease, but should be re-usable.
    Cut to the chase: I've located a QV front end that can be parted out, and I need to know if that subframe will fit my 1977 model. Somebody told me that the design changed over the 308 model years; even the radiator was tilted in later years. I always thought they were all vertical. I do believe the fan mounts may be different, but that doesn't matter, because I'll re-do my custom Hayden fans again (directly mounted to the radiator).
    The plan is to weld just that front section to my main frame, which is straight.
    Any advice/info is appreciated..
    Regards,
    Greg in Houston
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    greg,
    I know the front is the same from 78 to 83. For the 328, they changed the radiator to slant at an angle rather then stand up. I am not sure if that is the case for the 84-85 QV.
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Matteo..
    My car is a 1977, and the donor car is a 1985 QV.
    Can anybody confirm that the front box frames will interchange?
    Greg
  4. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    Log into the parts section of owners.ferrar.com and compare the bits........It looks like they do and most of the part numbers are the same
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Andrew...
    Greg
  6. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    I've logged in to owners.ferrari.com, parts pages, but for the life of me I cannot locate any 308 body frame diagrams...
    Can anybody provide a direct link?
    Thanks,
    Greg
    1977 308 GTB USA
  7. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    As long as both are US spec I would think they are the same, the euro tubes and bumper mounting is all different.
  8. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Newman, good info..
    Greg
