Question About 328 Alternator Charging | FerrariChat
Discussion in '308/328' started by Lawrence Coppari, May 8, 2020.
  1. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    I have owned my '87 328 for 32 years. One question I have always pondered is why do you have to blip the throttle to get the alternator to begin charging and for the idiot light to go out. I know it is not charging until I rev it because I can turn on the dome light when the engine first starts running. As soon as I rev the engine, the alternator light goes out and, simultaneously, the dome light brightens. No other vehicle I have ever owned works that way. All the batteries in my 328 have a lasted a long time so I am sure nothing is wrong with my system.
  2. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Same on my QV. It is normal. I have seen it on multiple cars and airplanes. It is a function of the voltage regulator.
  3. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,136
    Southlake, TX
    Rob Lay
    you mean that's a bug and not a feature? :) I would miss it if it didn't do it. ;)
    Milkshaker0007 likes this.
  4. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    I do not understand why it was designed that way. I have owned a number of vehicles with Bosch alternators and none works like this. There are reasons for everything.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,900
    Mike 996
    I have always wondered the same thing. Clearly it is designed to work the way it does - an increase in throttle to initially "trigger" the charging system - but I can't imagine why it was done that way - what the advantage might be.
    FWIW, on my 328, often the initial cold starting high RPM idle speed is high enough to initiate charging/shut off the light but it is not consistent. Maybe it's supposed to do that all the time? If it did, then the charging would commence without blipping the throttle and this "question" wouldn't exist! ;)
