question about ECU transplant and CEL | FerrariChat
Discussion in 'Technical Q&A' started by 24000rpm, Feb 2, 2014.
  1. 24000rpm
    24000rpm F1 Rookie
    say I bought a euro spec 360 ECU and install it on a US-spec 360 car.
    then I install a non-precat header to the US-spec car, isn't that going to solve the engine light issue for good?
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,947
    The Cold North
    Tom
    What engine trouble code do you have? Swapping an ecu and headers may cost you far more then just fixing the problem in the first place.
  3. Fear.Engineer
    Fear.Engineer Rookie
    Oct 27, 2013
    17
    Poland
    Can You give us Ecu numbers. Maybe then I will be able to help.
    Best regards
    Kuba
    Wysłane z mojego GT-I8260 przy użyciu Tapatalka
  4. 24000rpm
    24000rpm F1 Rookie
    I have a wrecked 2003 modena, euro version
    and a US-version good 2003 modena,
    that's why I am thinking of replacing the US-version header with a Euro version header
    about the ECU number: is it printed on the ECU? i'll have to look that up
  5. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    You would need to pair the motronic ECUs with the alarm and transmission ECUs as well. A similar project was undertaken by another on the forum to replace alarm ECUs in a euro spec vehicle with those from a US vehicle. I believe there was a CEL issue in the end.
