Question about Novitec Wing | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by SAU KWENG TAN, Jun 5, 2018.
  1. SAU KWENG TAN
    SAU KWENG TAN Karting
    Feb 21, 2018
    104
    Hello All. I cannot recall if I ever asked this questions before. I try to google but all come out is selling sites instead of reviews.
    I like the Novitec Wing for the 488GTB. Any one know if it's for appearance purposes only and doesn't actually improve the car handling or maybe even make it worse. Any performance test number to prove the case?
    Will aftermarket wing like this devalue the car?
    Thanks.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Yep.
    obbob, Bigilo and DrewH like this.
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    Let us postulate that the wing actually creates downforce and does not upset the already existing downforce while doing so.
    In this case you will end up with progressively more understeer as speeds go up past 120 MPH.
    Is this what you want?
    You see, aerodynamic downforce needs to be balanced front and rear in order to maintain the superlative balance Ferrari engineered into the car.
    AshAP and SAU KWENG TAN like this.
  4. SAU KWENG TAN
    Feb 21, 2018
    104
    I do not drive enough to determine the under/over steer issue. Only been to track twice with other car. I like the look of the wing on this 488GTB but want to make sure it will not hurt the performance such as swaying or make the car unstable. I guess can change the front camber to fix understeer issue. Fix the back and need to work on the front. Cool.
  5. MrF355
    MrF355 Formula Junior
    Mar 4, 2008
    495
    Kimi
    Sau, respectfully, do you really think that adjusting camber will negate the negative impact of the wing. The Ferrari engineers spend millions to get the aero right and for permanent wings to not be required as has been the design philosophy of Ferrari for decades. Do you or any after market shop think they know and can do better than the factory engineers? You need to decide if you want looks or ultimate aero as the 488 was designed. If you want looks accept the negative effect of the wing and adjust your driving.
    DrewH and thorn like this.
  6. DrewH
    DrewH F1 World Champ
    19,401
    Vancouver, BC Canada
    Andrew
    The wing ruins a nice car.
