Question about oil suction fan, and jacking points? | FerrariChat
Discussion in '360/430' started by Falcon Wing, Apr 9, 2014.
  1. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    #1 Falcon Wing, Apr 9, 2014
    While doing my oil change, upon removing the oil suction fan, it had this whitish remnant left. Is it some sort of stop leak, like plumbers tape, dried molykote?
    Also, I have the molykote, and was wondering how much molykote should be used to lube the seals?
    Also, the rear jacking points are obvious, but looking at the owners manual, I am not 100% sure where the front jacking points are located. Anyone have any advice on that?
  2. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,113
    Calif
    Brett
    Hmm...not sure about the white stuff. Just lube the o ring with enough to lightly coat the o ring. Jack points in front are rear of wheel well...90 degree shape to the jack point...anywhere along there. I'll see if I can find a pic or take one tomorrow...hth
  3. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    #3 Falcon Wing, Apr 10, 2014
    Does this look about right?
  4. up4speed
    up4speed F1 Rookie
    3,681
    Long Island, NY
    Chris
    Yep, that's where I jack mine.
    That white stuff on the filter (fan) is strange. Is it like a plastic substance? Could it be packing material from the factory that was never removed when the part was installed originally?
  5. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    Not sure on the white stuff. Kinda seemed like oil soaked plumbers tape but was thinner than any plumbers tape I've ever used. It tore very easily.
  6. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Nothing further to add other than you can jack the entire side of the car up on the rear jacking point alone. That wil allow you to get an axle stand under the front jacking point and some blocks under the reat wheels (or stands on the chassis if you have the under tray removed).
  7. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,113
    Calif
    Brett
    yup...you got it. anywhere along that corner piece
  8. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    That looks so right !!! its even MY car :) at the dealer.
  9. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    My apologies for the stolen photo, thanks for originally posting! Though it would be easier than linking to the old thread (I actually used the search function).
  10. scudF1
    scudF1 F1 Rookie
    2,917
    Long Island, NY
    Billy
    It would be nice to mention at the beginning of your thread the model of your car!
  11. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    Noted for future, thanks.
    01 360 F1 Spider
  12. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Absolutely NO apology needed, I posted it because I thought it could help people after I had the same question and my dealer showed me. I just thought it was funny...
  13. High_Colorado
    High_Colorado Rookie
    Apr 2, 2012
    11
    N. Colorado
    Scott
    Heya, next time I see you remind me to give you some "jacking point sticker-arrows" for the next time you need to do this.... Could make things much easier if you are ever in a pinch!
  14. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    #14 Falcon Wing, Apr 14, 2014
    Don't tell me what to do.
