Question about RED LINE WATER WETTER. | FerrariChat
Discussion in 'Technical Q&A' started by SorpassoRosso, Apr 23, 2010.
  1. SorpassoRosso
    SorpassoRosso Karting
    Jun 5, 2008
    78
    Redline's Water Wetter, is a product designed to significally reduce engine temperature, when added to the vehicle's cooling system.
    Many people swear by it, so I finally decided to give it a try.
    Upon reading the label, the manufacturer strongly suggest that in order to achieve maximum results, the amount of 50/50 (water/antifreeze) should be drastically reduced (only 15% 0f 50/50, 75% distilled water, and 1 can of Water Wetter).
    Is this small percentage of antifreeze solution safe for SF or any other car ?
    Has anyone experienced mixing at different ratios with the same results ?
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  3. SorpassoRosso
    Jun 5, 2008
    78
    #3 SorpassoRosso, Apr 23, 2010
    Scuderia Ferrari. The abreviation "F Cars" doesn't sound like a good serenate, and could be easily misinterpreted as "something else". LOL.
  4. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,269
    Illinois
    #4 JohnnyS, Apr 23, 2010
    I calculate that 25% of a 50/50 mix + added distilled water will give you about a 12.5% glycol blend. A 12.5% glycol mix provides freeze protection down to about 25F. This is not safe in areas that experience cold temperatures!
    IMHO having 87.5% water/12.5%glycol mix has a higher heat capacity than a 50/50 mix and that is what will give you more heat removal performance. That may be where you get the added cooling performance.
  5. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    I use water wetter in all of my vehicles with great results the key thing is to know what the freeze protection level is in your vehicle.
    For example in my cars I run the 50/50 ratio with water wetter added into the cooling system.
    On my dirt bikes I run 5% Ethylene Glycol / 95% distilled water and 2oz water wetter per gallon. With this mix I have to run a higher pressure radiator cap as the boiling point is reduced. Also in the winter when the bike is stored the cooling system is drained fully.
    Water wetter works as advertised it will reduce your cooling system temps but how much depends on how much ethylene glycol is in the system as it reduced the amount of heat being transferred from the engine block to the coolant.
  6. JohnnyS
    Oct 19, 2006
    15,269
    Illinois
    Good points, it is early in the am and I had forgotten about the reduction in boiling point and pressure thing.
  7. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    686
    Delray Beach FL
    Russell
    If you google water wetter you should find all sorts of tests showing that it really does nothing, I use engine ice to replace the coolant in my sport bikes.
    Russell
  8. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Heat transfer to and from a liquid is a function of many properties of the liquid. I would like to cite the ones that enter the computations when one designs thermal systems: Thermal conductivity of liquid; viscosity of liquid, specific heat of liquid; density of liquid; surface tension of liquid (for boiling regimes/thickness of insulating vapor layer). System pressure also affects the situation. The properties are temperature dependent. Then there is the other end of the computation where the liquid must give its energy to the engine radiator followed by the heat leaving the metal of the radiator and being carried of the the passing air flow. The size/shape of the radiator affects all this. If radiator is undersized and cannot reject the thermal energy picked up by the coolant, additives that change bulk liquid properties might not help.
    It is a complex situation.
  9. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    I agree with this statement with respect to adding it to a water/antifreeze mixture. I wouldn't say "nothing", but definitely in the noise of what your temp gauge will read. However, if you add it to a pure water coolant system it makes a big difference. Many race teams use it with pure water with as advertised results. Even Redline shows the data to support this.
  10. Imola2001
    Imola2001 Formula Junior
    Jul 17, 2005
    889
    SoCO & SoCal
    Mike C.
    I run it with pure water in my "track car". During the off-season it sits in a heated garage, so I do not worry about it freezing, and am only interested in keeping the temps down while at the track. None of my other cars run water wetter.
