Question about revs | FerrariChat
Question about revs
Discussion in 'Technical Q&A' started by Mantinger, Mar 31, 2009.
  1. Mantinger
    Mantinger Karting
    Jul 30, 2004
    145
    Netherlands, Drenthe
    H
    #1 Mantinger, Mar 31, 2009
    Some time ago somebody told me high revs in neutral or clutch engaged (showing the sound of the engine by trafficlight or on demand) can really damage the internal parts.
    Exists mechanical difference between high revs under heavy acceleration and high revs on standstill?
  2. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    High revs (within 20% of redline) unloaded (in neutral), especially large changes in revs in the upper range, can be detrimental to engines with high piston speeds. Without loading the engine components by "work," the random "floating" of the internal engine parts does not promote even wear, is prone to overspeeding and is a great strain to chains and belts.
    An accelerating (and decelerating) engine that is loaded (weight and inertia of the car) slows the rate of change, is less likely to overspeed (go beyond the indicated engine rpm) and makes uniform the thrust loads on the piston crowns, valve gear and bearing surfaces in the bottom end.
  3. Mantinger
    Mantinger Karting
    Jul 30, 2004
    145
    H
    Thanks ProCoach! So even loads are better and save the internal parts from overspeeding and sudden speedvariation.
    Appreciate!
