Question about small evap leak | FerrariChat
Discussion in 'Technical Q&A' started by up4speed, Dec 14, 2014.
  1. up4speed
    up4speed F1 Rookie
    3,702
    Long Island, NY
    Chris
    I'm asking this question for a friend because I don't think he is active on the board.
    He has a 2002 (I think) 360 spider. His check engine light comes on after he fuels up. I checked it and cleared it for him, but it comes back with every fill up (small evap leak code). Once I clear it, he's good for the remainder of the tankful.
    Has anyone run into this before? Is it possibly the gas cap?
  2. windsock
    windsock Formula 3
    1,160
    It is likely the rollover valves. The test is only run between 3/4 and 1/4 of a tank and the closer to full the tank is the more sensitive the test so it makes sensor that at the early stages of a rollover valve failure it would occur at close to 3/4 and be ok for there.
  3. up4speed
    up4speed F1 Rookie
    3,702
    Long Island, NY
    Chris
    Ok thanks!
    When it first happened and I confirmed that his gas cap was on tight, I told him that I thought it was the roll over valves, but since I cleared the code and it didn't come back, I thought it was a one time freak out. Once it triggered again with a fill up, I got confused. Thanks for the advice I'll tell him that he needs to have the dealer look at it.
